Old 01-03-2007, 06:40 PM   #1
98skuby
Member#: 52632
1998 impreza rs
black
Default 98 rs engine to a 98 legacy?
anyone know if a 98 rs stock engine will fit and work in a 98 legacy?
james
98skuby is offline   Reply With Quote
Old 01-03-2007, 07:12 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Legarus...
Old 01-03-2007, 08:20 PM   #3
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
yes it will fit.
MeanEditor is offline   Reply With Quote
Old 01-03-2007, 09:22 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
It's the same engine as a 98GT.
For future reference, all EJ engines and EJ transmissions will bolt up to all Legacys, Imprezas, Foresters, etc. Actually the EZ engines fall into that too.
Wiscon_Mark is offline   Reply With Quote
Old 01-03-2007, 10:10 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
Why go through the trouble of installing an equally old stock engine?
KD7000 is offline   Reply With Quote
Old 01-04-2007, 01:12 AM   #6
spdracr00
Member#: 65823
1996 Impreza L
Red
well, sorta, any newer 2.5SOHC 2000+ from an impreza will not "just drop in" to a legacy. there are some hardlines that are different. I know because i bought a 2000 2.5rs engine to put into my 99 legacy when i blew a HG and it was not the same.
spdracr00 is offline   Reply With Quote
Old 01-04-2007, 01:18 AM   #7
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
There are also differences in MAF vs MAP between the years.
subiekid is offline   Reply With Quote
Old 01-04-2007, 01:50 AM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Yes, that also went along with the Phase 2 revision.
rougeben83 is offline   Reply With Quote
Old 01-04-2007, 12:25 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
To get a bit off topic...
What about sensors? Obviously the MAP/MAF thing is the big one that everyone points out, but what about other sensors? I've thought about converting to a SOHC ECU for the possibility of reflashing it, but if I have to rewire things completely that would suck. (And yes, I realize that the SOHC ECUs have different plugs than our DOHC ECUs, I'm looking past that for the moment.)
Pat
Old 01-04-2007, 12:31 PM   #10
spdracr00
Member#: 65823
1996 Impreza L
Red
you just reuse your old manifold with your old sensors is the best way i found. but if you wanna use a stock SOHC motor then yeah, you have to rewire it and thats a pain in the butt. besides if you use the sohc 2.5 with a dohc 2.5 exhaust manifold you get higher compression and more power.. cept you will have to run prem fuel.
Old 01-04-2007, 03:07 PM   #11
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
we are running a 2.5RS heads on an STI block and our stock 97 LGT harness plugged in with no issues.
You just need to use your same intake manifold as there seem to be differences even between a model years and models.
Old 01-04-2007, 04:19 PM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
Kindly explain to me how you managed to bolt up the in-line bolt pattern of the DOHC Ej25 manifold to the offset pattern of the SOHC Ej25 heads?
Old 01-04-2007, 04:25 PM   #13
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Maybe he swapped heads?
Of course that would mean a lot more work...
Old 01-04-2007, 07:11 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
That's totally different than what he is giving advice about. Pat Olsen already has an phase II shortblock mated to his phase I heads in his GT. What he was asking about was installing the COMPLETE SOHC Ej25 engine. And spdracr seems confused about more than just that since the exhaust manifold has nothing to do with one's compression ratio. It's the use of the phase II block with less piston dish that makes the compression go up with mated to the phase I DOHC EJ25 heads...
Old 01-05-2007, 12:42 AM   #15
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Oh, I was reading that wrong. I was thinking intake manifold.
duh!
Old 01-07-2007, 08:31 PM   #16
iluvdrt
Member#: 46248
82 Brat
Tan
What did you do for engine management, and injectors? Did you change the fuel pump? I am thinking about doing my swap again.
iluvdrt is offline   Reply With Quote
Old 01-08-2007, 12:02 AM   #17
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
In doing essentially the same thing this weekend ('98 2.5RS into '97 2.5GT) I found that there are some slight differences in the intake manifolds and the vacuum lines. Here are two pics of the 2.5GT intake manifold, followed by 3 pics of the 2.5RS manifold.
Here you can see no vacuum lines coming off the passenger front to whatever that black canister is. (Fuel vapor recovery I think?)
Here's that little nub that's tapped, but as you can see there's a plug in it, so I don't know why it's that way.
And here you can see the TB only has two vacuum connections to it (although there are ports there for more, but then the bump on top of the plenum is tapped and has a hose nipple, so there are still 3 connections there total.
The intake manifolds are identical, just for whatever reason the 2.5RS one has a couple spots tapped that aren't tapped on the 2.5GT one. Weird. Because I would have to remove the intake to get to the vacuum/fuel vapor vent lines anyway, I'm just swapping the whole intake manifold from my original engine over to the "new" engine.
Pat
Old 01-08-2007, 12:25 AM   #18
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
No H6 project, eh Pat?
Good Info though
Old 01-08-2007, 12:55 PM   #19
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
Pat,
The reason for the differences is that the 98+ impreza has the pcv canister at the rear of the car, whereas the 97 legacy has it in the engine bay.
When I put the 98 Impreza motor in my car, I did the same and reused the 97 intake manifold and all the associated vacuum lines, etc. It made for a much simpler swap.
Dan Cech is offline   Reply With Quote
Old 01-08-2007, 06:40 PM   #20
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Eventually. The EZ30R and an STI 6-speed are both sitting in my garage. (My impenetrable, locked garage.) Probably next summer?
Originally Posted by Dan Cech View Post
Pat,
Roger that, thanks, Dan.
Pat
Old 01-09-2007, 01:55 AM   #21
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
The PLAN was for a stand-alone, but we were in a jam and a PP6 went in, now we are going to do the stand-alone, PP6 just can't deal with big injectors. We have a walbro 255, we used an old single turbo Supra adaptor kit. Injectors are Stock STI at the moment but we have a set of modded stock 97 LGT injectors that look to be about the same as modded STI side-feeds. But we will flow test and see.
Old 01-09-2007, 10:05 PM   #22
iluvdrt
Member#: 46248
82 Brat
Tan
What is the supra adpater kit?
What are you useing for the standalone, an APEXI AFC?
98 Impreza L to a 98 Impreza RS Subaru Tech Subaru Conversions 0 02-18-2008 09:50 PM
FS: 98 RS converted to wrx with mods gc8ej20 Private Vehicle 'For Sale' Classifieds 0 01-31-2007 12:15 PM
FS: 98 RS converted to wrx with mods gc8ej20 Private Vehicle 'For Sale' Classifieds 0 01-31-2007 12:10 PM
98 rs engine hydrolic lifters subajay Normally Aspirated Powertrain 4 09-20-2005 12:40 PM
swap a 98 wrx engine into a 93 legacy..help!! BLOPA Subaru Conversions 1 05-11-2004 10:02 PM
