Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 01-10-2007, 12:18 AM   #1
CouvSubaru
Member#: 137171
Question 1999 Legacy - Oil Leak Problems
Hey everyone,
I've got some questions about a 99 Legacy L, 64k miles, 2.2 litre. There is a small to moderate oil leak and the mechanic diagnosed the problem with these two lines:
Oil leak behind timing cover. Valve cover gaskets leaking into spark plug wells - recommend replacing.
Anyone have any ideas on this topic? He quoted about 300 dollars to replace the appropriate parts with labor. If anyone has had this problem before or has any thoughts at all please let me know. If something else could be causing the problem or if the mechanic is overcharging I'd like to hear your ideas - it would be much appreciated.
CouvSubaru is offline   Reply With Quote
Old 01-10-2007, 12:59 AM   #2
spdracr00
Member#: 65823
1996 Impreza L
Red
ok, yeah.. the valve cover gaskets are about $30 and you can do it with out pulling the engine. the $300 comes from having to drop the tranny to access the "oil seperator plate" which is made of plastic and does leak, subaru later fixed this with a replacement metal peice. so to be honest if you have the $300 sounds like a decent price. it is a little weird to have the valve covers go at 64k...
spdracr00 is offline   Reply With Quote
Old 01-10-2007, 03:10 AM   #3
Radeon
Member#: 105251
13 BRZ,STI
His mechanic said nothing about rear leak. Valve cover is super-easy, and might just need simple tightening (to specs). $50 job at most with new gasket. Timing cover leak - probably cam/crankshaft seal. This one requires taking off timing belt. With your milage its kinda early. So if the belt is in good shape I'd just ignore it, keeping an eye on oil level once a week or two.
Radeon is offline   Reply With Quote
Old 01-10-2007, 03:15 AM   #4
spdracr00
Member#: 65823
1996 Impreza L
Red
whoops, my bad.. all i read was "behind cover". haha..
Old 01-10-2007, 08:32 AM   #5
Dodik
Member#: 122609
2002 Outback H6 BE
82 GS750E
Don't know much about ej22 but in my ej25 leak from timing cover meant new oil seals!!!! they are like $10 each and there is 4 of them but labor cost me 400. dont know if you got the same problem or not but if you leak a LOT then its probably front oil seals.
Dodik is offline   Reply With Quote
Old 01-10-2007, 11:38 AM   #6
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
That would be your front cam or crank seals leaking if it's behind the timing belt cover. The leak probably isn't anything significant (just messy) so wait for your next timing belt job and have it done then to save on labor.
Wiscon_Mark is offline   Reply With Quote
Turbo Oil Inlet line > block, oil leak problems? RSblood Service & Maintenance 5 11-04-2008 01:12 PM
1999 legacy gt brake problem fred6870 Legacy Forum 2 08-20-2008 09:26 PM
2.2 oil leak problem Kitsune Normally Aspirated Powertrain 1 03-12-2004 04:14 PM
Common oil leak problem?? Puyo Newbies & FAQs 1 03-14-2003 10:19 PM
turbo/oil leak problem.... kid22 Technical Forum Archive 10 09-22-2000 12:45 AM
