Old 01-10-2007, 10:35 AM   #1
hybooststi
Member#: 83843
STI/EVO
Impreza WRX STi random misfires everyday???
hey guys ive been gettin misfire codes in each cylinder constantly.
i clear the codes they come back, just changed the plugs,using ngk' 1 step colder.ihave a 04 sti forged pistons,sz55w/tial44mm ewg,fmic,utec,pe 850's
etc..... the car has mad 456whpand 472torque on a dynojet.
anyways theres not much difference in lack of performence just curious on why im getting this. last time i had a broken ringland ,now i have a new shortblock. we did a compression test and everything read even across the board. might be the power enterprise inj. anyone with expierence wanna chime in ,thanks in advance. i understand these do happen just curious on why so often, something else may be wrong!!!
no blue smoke or black smoke on start up or idle, some white smoke but no smell.
k.c.
hybooststi is offline   Reply With Quote
Old 01-10-2007, 11:25 AM   #2
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Do you have a lightweight flywheel?
If so, that might be your answer. If not, it might be your coil packs if the CEL calls out one or two cyls regularly. If so, swap them around to see if the CEL plays follow the coil pack.
Old 01-10-2007, 03:54 PM   #3
hybooststi
Member#: 83843
STI/EVO
ah i forgot about that , good one. i did recently put in a exedy twin disc
that comes with its own lightened flywheel. good point and i doubt its the coilpacks but ill try, i do get the same amount of misfires from them all . it just sucks to see the cel and cruise blink but i can deal with it, i was just curious if something i might have over looked or what not. thanks
k.c.
Old 01-11-2007, 11:40 AM   #4
east milford wrx
Member#: 102301
+1 sounds like the fly wheel.
east milford wrx is offline   Reply With Quote
Random Misfires and Lean MMWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 06-27-2008 03:55 PM
Knocking...Random misfire skatefather Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-07-2008 12:25 AM
Random misfires after clutch install?? EJRex Built Motor Discussion 7 09-16-2007 08:38 PM
Random misfires, all cylinders stevepius Engine Management & Tuning 2 01-26-2005 05:58 PM
random misfire code #4/cel 0304 harvey oh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-29-2004 08:23 PM
