Old 01-10-2007, 11:51 AM   #1
sc00ter
Member#: 117767
2015 WRX
CWP
Default 02 Sensor or MAF sensor??
Would a bad MAF have anything to do with low idling rpm's (idling below 500 rpms with random jumps up to 800 rpm's) as well as power dips around 2k - 3k rpms in almost every gear?
If not the MAF, then could it be the 02 sensor?
CEL code is P0131 ( 02 in bank 1 to lean) by the way
Thanks for any help.
sc00ter is offline   Reply With Quote
Old 01-11-2007, 02:38 AM   #2
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
It can be both. But from the CEL, it would point more the the front O2/front A/F sensor.
-paK +1
Pakin is offline   Reply With Quote
Old 01-11-2007, 08:46 AM   #3
sc00ter
Member#: 117767
2015 WRX
CWP
thanks for the info.
Old 01-11-2007, 10:49 AM   #4
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
You need to check anything that can cause a lean cond. Map sensor, fuel filter/pump, plugged injectors, vacuum leak, air leak between the map and throttle body. O2 code is prob. the result not the cause.
crampfan is offline   Reply With Quote
WTB: 02-07 WRX MAF Sensor SHIFTcanadian TXIC Private Classifieds 0 01-28-2008 03:36 PM
WTB: 02/03 WRX MAF sensor Happy_Days VIC Private Classifieds 1 10-21-2007 01:42 PM
Map sensor or MAF sensor kmt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-25-2007 11:01 AM
02-05 wrx MAF sensor eddie1982 Private 'Wanted' Classifieds 5 05-14-2006 11:22 AM
02-05 WRX MAF sensor eddie1982 Private 'For Sale' Classifieds 1 05-11-2006 01:25 PM
