Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 01-10-2007, 05:53 PM   #1
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
Question How do you repair scratched lower cladding
Okay, so this is what happens when you go d***ing around in the dark, somewhere you've never been before, a week after terrential rains. I got stuck here about a year ago and didn't see the big rain washout rut, and it scratched up the lower cladding on the passenger side. Replacing the cladding is like $700-$800 (both doors, sills, a little back & front bumper). The scrapes aren't too, too deep. I was thinking of buying some of that textured spray paint but then that means I gotta do all the sides to look the same. I'd probalby be better off going to a body shop. But does anyone know can you sand this plastic stuff without losing the color? Or should I just sand it and then have it painted at the body shop? I also wonder if the body shop can order that color paint for the cladding, or if they typically replace the cladding so it doens't require painting.
Any ideas, suggestions, or even smart a** remarks about my stupidity are welcome.
wrenchwoman is offline   Reply With Quote
Old 01-10-2007, 08:45 PM   #2
primeministerp
Member#: 77950
2003 Baja
Black/Sliver
I had to goto a body shop to have mine repaired the first time, then got hit w/ a carrage in a parking lot the day i picked up the car. Now looking to have the whole baja painted flat black to make it easy.
primeministerp is offline   Reply With Quote
Old 01-10-2007, 09:19 PM   #3
YooperBaja
Member#: 64311
2003 Baja
[quote=wrenchwoman;16615235] The scrapes aren't too, too deep. I was thinking of buying some of that textured spray paint but then that means I gotta do all the sides to look the same.
Check into a place that does the liquid truck liners, they can be a cheaper alternative to a body shop and it can be done uniformly and I would think much cheaper. They do an entire truck bed for a couple hundred bucks, a panel or two should be much less. I'm giving thought to having the bed done on my Baja as it isn't as slippery as the plastic liner that came from the factory.
~YooperBaja
YooperBaja is offline   Reply With Quote
Old 01-10-2007, 09:41 PM   #4
cliffhanger
Member#: 80446
2005 5spd Baja-T
>300WHP White/Silv Cruck
i was thinking of having my entire baja covered in bed liner.. it's a toss-up between that and fur. are these scratches or gouges?
cliffhanger is offline   Reply With Quote
Old 01-10-2007, 10:07 PM   #5
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
Originally Posted by YooperBaja View Post
Check into a place that does the liquid truck liners, they can be a cheaper alternative to a body shop I'm giving thought to having the bed done on my Baja as it isn't as slippery as the plastic liner that came from the factory.
~YooperBaja
That's actually a pretty good idea--I'll have to see who does it around here, and for how much. I know it's gotta be cheaper than repairing/replacing body parts. Thanks!
As far as getting your bed done, you know you'd have to have them tape alot of it off so you can take the screws out if you ever needed to. I guess the people that do the rhino spray know what they're doing though.
Old 01-10-2007, 10:09 PM   #6
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
Scratches for the most part--I wouldn't say gouges although the pictures may look like they're gouged. They're just wider scratches, but not deep.
Old 01-11-2007, 11:04 AM   #7
kev m
Member#: 128582
2010 Impreza 2.5 Wgn
2011 Nissan Juke
Hard to tell from the pics, but could most of it buff out???
kev m is offline   Reply With Quote
Old 01-11-2007, 11:18 AM   #8
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
I don't think so. Especially since it's plastic. I did take a small sanding block last night to the front section behind the tire--you can kinda see a lighter looking gray area. That did help but it'll need painting when I'm done. If I do get it painted and not sprayed with the bedliner stuff, I'm going to have all the lower cladding and bumpers/tailgate done in black-black. Not the Obsidian black, or whatever the color of the rest of the car is.
Old 01-11-2007, 11:33 AM   #9
kev m
Member#: 128582
2011 Nissan Juke
I like the bedliner idea.
Rough, tough, and probably easily touch-up-able.
Heck, when I get a couple of years on mine, maybe I'll have that done to cover all the scratches and goop that will be on my cladding by then!!!
Old 01-11-2007, 03:04 PM   #10
Pursuit
Member#: 38370
I thought chicks dug scars?
I looked into having all my lower cladding done in bedliner, it was going to be close to $3k after all the labor of removing and putting back on was factored into it. It would look awesome though (I think...).
Pursuit is offline   Reply With Quote
Old 01-11-2007, 03:22 PM   #11
kev m
Member#: 128582
2011 Nissan Juke
They can't mask and spray on car I guess?
Old 01-11-2007, 03:32 PM   #12
Pursuit
Member#: 38370
That's what I was hoping for but if you look closely there's lots of lips that overhand and undercut each other etc.
Old 01-11-2007, 03:37 PM   #13
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
Can't argue with that! Scars are sexy are people, or on other people's Bajas. It sucks when they're on your own car.
Old 01-11-2007, 03:41 PM   #14
kev m
Member#: 128582
2011 Nissan Juke
Screw the overhangs, who cares if it is all getting colored the same color. The stuff doesn't have to come apart right?
Old 01-11-2007, 03:51 PM   #15
wrenchwoman
Member#: 126445
2004 Turbo Baja
Obsidian Black/Gray
Okay, I stopped by the body shop today and asked them about those scrapes. He said either get the parts from Subaru myself or else if he gets them he'll have to mark them up and it would cost more. Or he said they could fix what I have but it requires special prepping for plastic so the new paint adheres and doesn't crack shortly thereafter. He said wash it first and come back so they can see the extent of the scratches but looking at it the way it is dirty with the stuff he could see, he said maybe about $600 to repair and repaint with the original color. I know the parts cost more than that. I'd get the parts for a matter of a couple hundred dollars if they definitely come color coded.
Old 01-11-2007, 04:28 PM   #16
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
I would see if they can be buffed out first. it's hard to tell because once you use sand paper on black it turns gray which is the under color.. what grit did you use? was it 1000 at least.. I hope....if you were closer I would gladly do it.. but your a few hours away..
holland_patrick is offline   Reply With Quote
Old 01-11-2007, 10:41 PM   #17
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
WOW... That, I bet, was fun. Did you get stuck? Dont worry about the scratches if you are going to take it Off Road again as things might happen again. They scratches are going to stay unless you repaint the car. Its worth it to you?
Alex
BajaT05 is offline   Reply With Quote
HELP: How do you repair a loose clutch switch connector? lowkey General Community 0 01-22-2005 12:03 PM
How do you guys with lowered suspensions NOT bottom out? dr_wheel Off-Topic 27 08-26-2004 12:01 PM
How do you remove scratches ? zeroFX Newbies & FAQs 5 05-19-2002 09:39 PM
How do you remove scratches? zeroFX Interior & Exterior Modification 7 05-19-2002 05:22 PM
How do you remove scratches ? zeroFX Vancouver Impreza Club Forum -- VIC 2 05-19-2002 01:23 PM
