Old 07-07-2007, 03:09 AM   #1
03SuBbYWrX
Member#: 122785
2003 WRX- ej257 swap
w/ TD06H 20g 8cm
Default Check Engine Light Code-P1301 Please help
Ok so about 4 months ago i had a turbo upgrade and went full catless everything. Its been fine as far as codes for all this time. Now for some odd reason im throwing high exhaust gas temp codes left and right. First it was code P0546 (Exhaust gas temperature sensor circuit hight input), then it was code P1544 (High exhaust gas temperature detected). I went to my shop yesterday and i had the tuner reflash the code out completely cause they are harmless codes. The first one was because my egt sensor is f*cked. Second, when the code came on it wouldn't let me rev it when i tried to downshift then it wouldn't let me go, then it finally let me rev and nothing was wrong. The car went into a safe mode i assume. But now just today i was driving and my check engine light started blinking so i pulled over to check the code with my accessport. It was code P1301 (Fire due to increased exhaust gas temperature). I was like okay its just another high temperature code so i went to let off the clutch and push the gas and the car moved like an inch then died. i tried again and again and it still just died. I reflashed my realtime map back into the ecu and the code went away and the car didn't die but it did die about 10 seconds down the road. (This was when i plugged the accessport out). Next, i did the same thing but kept the accessport plugged in and it drove fine and i was able to get it home). I have to go do a lot of things tomorrow and im afraid if i drive it it will do the same damn thing. So basically what im asking is what the hell is (Fire due to increased exhaust gas temperature). Cause there was no fire just a car that died when trying to roll out. But ya also, why did the car die all the time. Has anyone had this happen to them or had all these cels in a short period of time with high exhaust temps after the car didn't throw any codes for a while. Im going to call my shop tomorrow and see what they say, but i also wanted to see what you guys would say about this. Thanks
03SuBbYWrX is offline   Reply With Quote
Old 07-08-2007, 08:21 PM   #2
capitalj4
Member#: 136309
2003 wrx
blue
im having the same problem right now. my car doesnt stall out anymore tho. but i keep throwing the same codes. i took my car to the local subaru dealership and they did a ecu update, this helped me otu a bit, for a bout a day. now im back to the same problem! please keep me posted as to if you fix it or not, and what the problem is. ive had it for about a month now and i still cant figure it out
capitalj4 is offline   Reply With Quote
Old 07-23-2007, 01:57 PM   #3
fast71
Member#: 123735
2002 WRX PSM /2.5
Turbo_mike built, PPG'D
what was the outcome? I was able to fix my problem.
fast71 is offline   Reply With Quote
Old 07-23-2007, 07:24 PM   #4
capitalj4
Member#: 136309
2003 wrx
blue
glad you got yours fixed! i still have no clue on what mine is. its been like thi for over 2 monts for me now, and me/technicians at work/subaru dealership. no one can seem to find the problem. im jsut going to keep on looking. ill keep you posted on what i find out tho!
Thank-you!
Old 07-23-2007, 07:57 PM   #5
TMessick
Member#: 882
2004 WRX Wagon
very blue
DTC P1301 — MISFIRE DETECTED (HIGH TEMPERATURE EXHAUST GAS)
1. OUTLINE OF DIAGNOSIS
Detect whether the misfire occurred or not. (Exhaust temperature method)
4. DIAGNOSTIC METHOD
Judge NG when the malfunction criteria below continue 200 engine revs. (400 ignitions) in a row.
Amount of intake air < 60 g/s
Exhaust temperature > 1050°C (1922°F)
Read this Uppipe FAQ. Twice....
Then go buy yourself a 2.2 KOhm 1/2 watt resistor and thank Unabomber.
TMessick is offline   Reply With Quote
Old 07-23-2007, 09:03 PM   #6
fast71
Member#: 123735
2002 WRX PSM /2.5
Thank-you!
check this out.
http://www.clubwrx.net/forums/showth...highlight=2.2k
Problem solved!!
Check engine light codes? Shifty Eyes Engine Management & Tuning 4 11-16-2004 04:20 AM
P0137 Check engine light code 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-15-2003 06:56 PM
Check engine light code 1443??? k2snow North West Impreza Club Forum -- NWIC 9 06-05-2003 06:51 PM
Check Engine Light Code 103 bmwk12rs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2001 12:10 AM
Pulling the check engine light codes Attn: ColinL and anyone else BoomerRS Technical Forum Archive 7 09-12-2000 11:45 AM
