#1 |
Member#: 71172
Vehicle:95 LegoOutbackfied |
Hello everyone
i just aquired a 93 impreza... its a good little car its my first impreza i have been a legacy owner for years the only electrical issue is the blower fan, it works on the 4 speed only, do you guys hav an idea what it may be?? thanks in advance Neo
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Sounds like a burned out blower motor resistor, it's a fairly cheap and easily replaced part.
#3 |
Member#: 71172
where does the resistor resides? i may be able to get one at the junk yark
#4 |
Trust no one
On the newer cars it's located in the HVAC housing, down by where the fan is. Probably in a similar location on yours, it's placed there so it's in the airflow for cooling as the resistor element generates a lot of heat.
Look for a second electrical plug near where the fan plugs in, if it's attached to a small module that screws into the housing that's it. |
#5 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
Yeah, those resistor failures can be common, especially with higher mileage cars. All sorts of crap can get into them despite being a surrounded by a protective cage.
-paK +2 |
#6 |
Miss You Mom
Oct 1940 - Feb 2008 Super Moderator Member#: 809
NESIC
Vehicle:2000 2.5 RS, '14 For 92 5MT SVX |
#7 |
Member#: 123741
Vehicle:1998 OBS Black |
Not trying to hijack this thread, but I have a similar problem. I don't have any fan most of the time. Every once in a while I get all 4 speeds available. I tried replacing the resistor and it didn't fix the problem. Any thoughts?
Neo, Not sure if your car uses the same part number, but I have a brand new resistor for sale now. My car is a 98. Let me know if you want it. Todd |
#8 | |
Member#: 120368
E. Canada
Vehicle:02 WRX Wagon PSM |
#9 |
Member#: 71172
yes i have found the problem its was the resistor, i changed it with one from the junk yard and bingo it worked
#10 | |
Member#: 104893
Vehicle:2005 Impreza WRX Obsidian Black Pearl |
#11 |
Member#: 120368
E. Canada
I had the same problem and found out it was a bad blower motor relay. It was intermittent on all speeds.
#12 |
Member#: 177742
Does this apply to Impreza 95'?
#13 |
Member#: 71172
yes it does
#14 |
Member#: 118209
Vehicle:2002 WRX Sedan |
it applies to ANY car that has a multi-speed blower made in the last 30 years. Some cars have multiple combinations of resistor packs, so it is possible to have speeds 2 and 4.
| Thread Tools | |
| Display Modes | |
| 1986 subaru gl trans on a 93 impreza fwd 5 speed | soobxnoob | Transmission (AT/MT) & Driveline | 3 | 04-16-2010 02:39 PM |
| WTB: stock 93-97 impreza radiator fans | jicc | Private 'Wanted' Classifieds | 2 | 05-27-2009 12:48 PM |
| Fs: (de) 93 Impreza 5 Speed 4 Door Wrx Upgrades Sti Rear Seat 1700 Obo | blueghost | Private Vehicle 'For Sale' Classifieds | 13 | 09-05-2008 12:19 AM |
| Heater blower fan only works on High? | dg_performance | Service & Maintenance | 4 | 01-29-2008 09:46 PM |
| 93 impreza L top speed? | speakerman86 | Normally Aspirated Powertrain | 43 | 01-14-2006 07:47 PM |
