Old 01-10-2007, 09:37 PM   #1
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
Default Timing belt change
I'm about to do a timing belt change to my car, what all do i need to purchase so I dont have to go through it again? Where would be a good place to purchase the product? Dealership or Autozone/Pepboy...etc?!
02aspenwrx is offline   Reply With Quote
Old 01-10-2007, 09:43 PM   #2
BillJC
Member#: 31002
Get a Subaru Belt. You don't need anything different. That and change the water pump and T-Stat while you're in there. I sourced mine from a dealership.
BillJC is offline   Reply With Quote
Old 01-10-2007, 09:54 PM   #3
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
How much did the parts run you?
Old 01-10-2007, 10:02 PM   #4
novacivic
Member#: 117980
2005 sti
wr blue
At the dealer we dont replace the pump or thermostat unless it is leaking which doesn't happen all too often. But I do recommend getting the subaru belt and replace the tensioner as they are prone to leaking and loosing tension. Buy your parts from us at www.subaruwrxparts.com you'll get a great discount if you order the parts from us online.
novacivic is offline   Reply With Quote
Old 01-10-2007, 10:28 PM   #5
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
As my first question has yet been answered, what all do i need for the timing belt change?
Old 01-10-2007, 10:33 PM   #6
norexyet
Member#: 39149
11 elantra
yea i said elantra
Get a non-stretch belt, they are only a bit more money, water pump, tensioner, t-stat and gasket. May be a good idea to swap in some new accessory belts. Just basic hand tools. Drain the coolant, pull the radiator. Remove acc. belts and belt tensioners, timing covers. You will want to hold the cam gears in place also.
norexyet is offline   Reply With Quote
Old 01-11-2007, 12:12 AM   #7
02aspenwrx
Member#: 61001
02 AW Wrx - SLOW!
2011 STi Limited
gotcha, my ps pump is going as well so ill be replacing that as well.
So in other words only part that should really be OEM should be the belt?.
Old 01-11-2007, 10:35 PM   #8
eb1888
Member#: 115226
2005 wrx wagon
You would benefit from the service manual pages or Scoobymods. A non stretch belt is kevlar reinforced-Power Enterprise $178 at Z-1 Performance. You need a hardened pin to pin the tensioner for install. The blue PE belt does not come with timing marks. I transfered them from a new OEM belt which was returned. Or you could mark your old belt after you rotate it to line up before you remove it.
eb1888 is offline   Reply With Quote
Old 01-11-2007, 11:59 PM   #9
norexyet
Member#: 39149
11 elantra
yea i said elantra
The PE timing belts are marked.
Old 01-14-2007, 08:32 PM   #10
eb1888
Member#: 115226
2005 wrx wagon
The one I used 6 months ago must have been one of the unmarked ones. Check with the vendor and ask for a marked one. It will be easier.
timing belt change steve_d Normally Aspirated Powertrain 5 12-04-2013 04:28 PM
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 06:46 PM
ok time for a timing belt change. speed_ga Legacy Forum 9 09-17-2008 11:19 AM
Timing belt change with seal change? file_id Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-09-2007 01:59 PM
timing belt change, anyone done their own? steve_d Normally Aspirated Powertrain 21 11-13-2000 09:38 AM
