South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 01-11-2007, 12:56 AM   #1
subyflynn05
Member#: 122624
Default sniff test
i have an 02 wrx with turbo back exhaust. the check engine light is on for the rear 02 sensor. my buddys fuse blew for the obd2 port, so they just took a sniff test, at emisions. i was wondering if i could clear the codes, take the fust out for the port, and take a sniff test. does anyone think this will work? or pass the emission?
subyflynn05 is offline   Reply With Quote
Old 01-11-2007, 01:06 AM   #2
boosted20
Member#: 79576
i don't get it
Edit: I think I know what you are trying to write now. If you take the ODB2 fuse out then the scanner will not work. As long as you do not have a check engine light you will pass. If you don't have a cat on the exhaust you will most likely fail an exhaust gas analysis.
boosted20 is offline   Reply With Quote
Old 01-11-2007, 01:10 AM   #3
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
thought i had it, but lost it.
you want to take a sniff test because your cel is on? or you want to take a sniff test after you clear your cel? seems to me that is going out of your way to do the same thing?
v8eaterWRX is offline   Reply With Quote
Old 01-11-2007, 01:16 AM   #4
subyflynn05
Member#: 122624
basically my question is do you think that it will pass the sniff test?
Old 01-11-2007, 01:19 AM   #5
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
iirc the sniff test is only done with the engine under load, and in order for the engine to be under load it would have to be on a dyno, and emissions doesnt have an awd dyno. i think you will have to do the obdII check.
Old 01-11-2007, 01:42 AM   #6
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Why not just fix the cause of the rear O2 sensor CEL? Mechanical or Electrical, both are easy...
I doubt they will let you take the idle sniff test instead of the OBD2 test, but I suppose you could try to slip by them.
AaronB is offline   Reply With Quote
*sigh* sniff sniff 2pt5RS South East Region Forum 11 12-10-2002 12:34 AM
Four Inspections and no sniff test Jonathan New England Impreza Club Forum -- NESIC 5 06-07-2002 01:44 PM
sniff, sniff...can you smell it.....Laker threepeat! zabutter Tri-State Area Forum 12 06-05-2002 09:44 PM
*sniff *sniff R.I.P. scooby dooby blu itsallgookx51 Bay Area Impreza Club Forum -- BAIC 18 11-13-2001 02:40 AM
('93-'01) Sniff sniff....mmmmmmmmm.... new car smell :P Ippon Impreza Forum 6 04-27-2001 06:57 PM
