Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-11-2007, 12:14 PM   #1
tekintl
Member#: 70080
2009 WRX Sedan
Default Introduction
Hey everyone I am new here, not really new to NASIOC but new to tuning and EM. I recently went the way of open source tools and am loving it.
If anyone is in the Atlanta area and is considering doing this then I would be happy to help. Or if any of you experienced guys don't mind giving a newbie a few pointers let me know (I will supply the beer .)
What I am currently using:
Tactrix cable
Enguinity (editing)
openecu (flashing)
Ecuexplorer (logging)
tekintl is offline   Reply With Quote
Old 01-11-2007, 01:04 PM   #2
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
You use EcuExplorer to FLASH and LOG.
You use Enginuity to edit your maps.
akira02rex is offline   Reply With Quote
Old 01-11-2007, 10:49 PM   #3
TMessick
Member#: 882
2004 WRX Wagon
very blue
Unless you've got an STi -- apparently, you need to use EcuFlash to flash some of the newer Drive By Wire ECU's (haven't tried, so I cannot confirm). On my '04 I use EcuExplorer, which has a simple flash program baked in (it may actually just be an older version of EcuFlash?)
Pointers?
-- Watch your EGTs, hot EGTs can waste exh valves and kill turbos. You can run an engine at WOT with lean AFR's with no issues at all if it's not knocking and EGT's are in check. If you run the same engine at 12:1 with retarded spark, you can end up with EGT's so high you'll actually melt the valves. A/F gauges are nice to get to the best power, but EGT is king for "safe" tuning.
-- Nature likes a "smooth" map. Do some graphing once in a while and see if there are any obvious holes/outliers. Double check those points, but chances are, they don't want to be vastly different than their neighbours.
-- Baby steps. Baby steps -- don't increase boost by 10psi and throw 20 deg of spark at it all at once....
-- Leave a "safe" fuel/spark cal in that is rich/cool and not too agressive on spark, then work out your boost targets and WG then work on fueling/spark
-- the 10 deg flat ignition correction is a good idea to be able to see where your ECU is pulling spark. Look up Ride5000's spark thread(s) -- good info there.
TMessick is offline   Reply With Quote
Old 01-11-2007, 11:07 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Pointers?
+12345
blkscooby is offline   Reply With Quote
Old 01-11-2007, 11:33 PM   #5
Freon
Member#: 88322
2009 BMW 135i
Ecuexplorer cannot flash the 2.5L turbo, DBW, 32bit cars. It can only flash the 2.0L turbo, DBC, 16bit cars.
Freon is offline   Reply With Quote
Old 01-12-2007, 12:09 AM   #6
wall of tvs
Member#: 29716
2006 wrx wagon
booze powered e85 monster
the flashing module in ecuexplorer is a VERY old version of ecuflash -- I think it was back from when it may have just gone from a command line program to one with a GUI.
wall of tvs is offline   Reply With Quote
Introduction amp5 Tri-State Area Forum 2 02-15-2014 05:14 AM
A formal Introduction from Exclusive Mods, Newest Vendor on NASIOC Exclusive Mods NWIC Vendor Classifieds 29 06-04-2010 03:49 PM
Introductions... natescape New England Impreza Club Forum -- NESIC 23 02-08-2001 06:01 PM
Introduction and a question: OBSS New England Impreza Club Forum -- NESIC 3 05-17-2000 09:00 PM
Introduction (new Portland area RS) DoctorMoo North West Impreza Club Forum -- NWIC 7 03-30-2000 07:44 PM
