Old 01-11-2007, 02:00 PM   #1
chokin
Member#: 124739
02 wrx
black
Exclamation cel P0447
hi guys..im a newbie...so the cel p0447 went on after i replace the front o2sensor, it might be have been on for a while, but i went to autozone or checkers, and the only code i found was the o2 sensor's one...i heard people said might be a lost gas cap to cause the cel P0447, but i sure i tightened it up tight and had tried it couple times....i really need help here guys and does it affect the performence of the car?
thanks!!!!
chokin is offline   Reply With Quote
Old 01-11-2007, 07:01 PM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
what kind of car? that is a evap code.
crampfan is offline   Reply With Quote
Old 01-12-2007, 08:22 AM   #3
chokin
Member#: 124739
02 wrx
black
sorry my bad....its a 02 wrx...i tried a new gas cap...but the cel went on again
Old 01-12-2007, 09:41 AM   #4
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
Old 01-12-2007, 10:21 AM   #5
chokin
Member#: 124739
02 wrx
black
Old 01-12-2007, 12:15 PM   #6
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
Evaporative Emission System Vent control Circuit Open
Rexwagon03 is offline   Reply With Quote
Old 01-12-2007, 12:40 PM   #7
chokin
Member#: 124739
02 wrx
black
i know that code but i just dont know how to fix it
Old 02-22-2007, 04:05 AM   #8
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
any luck on fixing it?
Old 02-23-2007, 06:30 PM   #9
20si06
Member#: 102876
WR Blue
I think I have the same problem, any one with a fix????
20si06 is offline   Reply With Quote
Old 02-23-2007, 10:59 PM   #10
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
talked with a subaru mechanic today. He says 1 of 3 possible problems
1) gas cap
2) some sort of repair is needed or just reading high caused by running rich or so on.
3) computer problem
#2 is a rather large area. ie... that is could be the hoses with the egr system or some other egr problem. It could be the wire problem as explaned in other post as near the rear passanger side sway bar black box problem. He also mention it could be nothing related to this system but could be something like running to rich in the air / fuel mixture. For my problem I am thinking running to rich as that was my last code. It was also bucking then like it is now. As my bucking happens mostly at full throttle. So I am going to see what plugs I can get and see if the problem goes away.
cel code P0328 and P0447 on my 01 RS CCTXRS Normally Aspirated Powertrain 1 09-12-2007 10:34 AM
P0182, P0447, P0452 Cel Codes jhzf Service & Maintenance 3 08-29-2006 10:59 AM
CEL P0447 And Access Port dtoxwrx Engine Management & Tuning 8 07-24-2006 05:05 PM
P0447 cel help Keo Service & Maintenance 1 08-13-2005 05:37 PM
CEL p0447 jn_ej205 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-03-2005 06:48 PM
