Old 11-25-2001, 03:27 PM   #1
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
Question MY 98 Intake design
I have come up with a design for a MY98 intake and I'm looking for feedback. I do not wish to make these for others, just myself so please don't ask I want to know if its possible and what type of problems I might run into. I've done searches for an intake and have not been happy with what I have found. If you guys and gals think it is possile I will do it and let others know if there are any problems.
The design:
Take a MY00 PDM intake and modify it to accept the MAF/MAS sensor. Basically just cut out a section and put the sensor back into the stock position using a MAF/MAS intake bracket (that some sell), and a couple of reducers w/silicon seals. The advanatges would be: use of the stock torque box, use of stock sensor, and having the intake feed in from the fender wall. This should give a little better performance than stock because it would eliminate the filter box and that restrictive flexible tubing. The downside: because of the reduction to the sensor would not be as effective as a true CAI intake. But it would be cheap to do and look a lot nicer than stock.
Thanks in advance!
Those Meddling Kids is offline   Reply With Quote
Old 11-25-2001, 03:30 PM   #2
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
Talking I have attached a pic for illustration purpose only!
My thanks to the owner of this pic and apologies for butchering it.
Old 11-26-2001, 01:48 PM   #3
HRE | giulio
Member#: 481
why dont you just replace the filter in the stock box with an AmSoil.
then remove the snorkel.
then remove the fog light cover.
then use a wire mesh to keep out leaves.
<img src="http://www.universeg.com/impreza/gallery/full/ramair.jpg" width=320 height=240 border=2>
g
HRE | giulio is offline   Reply With Quote
Old 11-26-2001, 02:43 PM   #4
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
Or.
you can do this
An then remove the fog light copletely and fab some ducting so it feeds to the intake.
I run a K&N but Amisols arejust as good.
Gives you nice little boost in throttle response and is dirt cheap.
RageHardIntoTheBendies is offline   Reply With Quote
Old 11-26-2001, 08:24 PM   #5
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
Thumbs up Good Ideas
I haven't given much thought as to increasing air intake on bumper but those are both good ideas. I assume you guys have not had any problems with that set-up. But, I still want to replace the stock intake, mostly for looks and cleaning up the engine bay. I not sure it would increase performance much, unless anyone knows if a cone type filter is better than the stock filter box.
BTW I already have a K&N filter and have removed the silencer, which has definitely helped, just looking to do a little more and cheaply.
TMK
Old 11-27-2001, 02:58 AM   #6
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Now, the way you make it sound, you would remove the first air filter and keep the filter in the air plenum. Is it safe to remove the filter in front of the MAF? You have the tougher 98 MAF, but I don't know if it is going to work right once you get some dust on it. Just a thought I had.
HondaH8er is offline   Reply With Quote
Old 11-27-2001, 02:42 PM   #7
akuhner
Member#: 462
2000 Impreza 2.5 RS
SCCA Rally Cross Car
H8er - No, that's far from safe! In '98s there isn't even a filter in the 'plenum,' as far as I know. I have a RalliSpec intake that does not go into the fender so the cone is attached to the front side of the MAF. I did take out the fog lights but that's because they stopped working and they are worthless POS anyway. So cold air does come in the hole where the intake used to be, but it's not really directed there.
Alex
akuhner is offline   Reply With Quote
Old 11-27-2001, 04:56 PM   #8
ShortyDCT
Member#: 9435
1998 Impreza OBS
white
so let's say you had fogs in your 98 and wanted to leave them in... and you get a CAI or any intake for that matter. What else can be opened up to get more outside air into the engine bay?
ShortyDCT is offline   Reply With Quote
Old 11-27-2001, 11:50 PM   #9
cakagan
Member#: 251
1998 Impreza 2.5 RS
Well, yer hood has 3 holes in it... Two vents and a scoop. Open the passenger side vent and the scoop. BAM! POW!
-chris
cakagan is offline   Reply With Quote
Old 11-28-2001, 08:57 AM   #10
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
H8er I would definitely have a filter before the MAF. I was hoping to attach it to the end of the intake, inside the fender wall, thus getting colder air away from the hot engine. I have not looked at how much space there is to do this, but I think it can be done. The problem would be moisture and puddles so some type of barrier would have to be created and maybe a small water trap. Or maybe I could run some type off panel filter that would be up against the end of the intake. The only thing that would affect the MAF is the filter being about a foot further away from it than the stock location. I don't think that wil cause any problems but advice is always appreciated. My only goals are to get some type of CAI and to have it look clean, and include the MAF.
TMK
Designing my own intake!!! elsuicida Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-10-2009 03:09 PM
My Intake Design KmanRuffian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-31-2006 09:14 PM
Cold Air Intake For MY 98??? SubaruLover Normally Aspirated Powertrain 5 07-16-2001 09:32 PM
I want my 98 intake! Grrr! Evil-Mastermind Normally Aspirated Powertrain 2 02-04-2001 10:24 AM
I am having trouble finding an intake for my 98. efoo New England Impreza Club Forum -- NESIC 11 07-29-2000 01:30 AM
