Old 01-12-2007, 11:55 AM   #1
stragglier
Member#: 137064
Default 1999 Outback Limited Issues
My 99 OUTBACK, stick shift limited has developed an oil leak that seems to be coming from the bottom edge of the front timing belt cover. I only have 45,000 miles on this car. The dealer says I might as well replace the timing belt and all the drive belts as he has to remove all of that or will be right there anyway to fix the oil leak.
One isn't 45,000 a little soon to have an oil leak and replace the timing belt;
Two where would it most likely be coming from??
How hard would it be to do it myself and what should I replace if I am in there anyway. IE working with the engine in the car it seems like a really tight space to work in, would I have to remove the radiator to get at it?
Also says I need a new right lower control arm bushing $440!! how hard is that for a backyard mechanic to do on the outback.
stragglier is offline   Reply With Quote
Old 01-12-2007, 11:59 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
it's not the mileage that is causing any issues
it's the AGE of the vehicle
oil seals will become brittle over time
regardless of if you drive the car OR NOT
You've obviously got a leak
if you're going to get in there, you're best off doing all maintenance at one time.
recommended:
timing belt, cam seals, front crank seal, oil pump oring and water pump
at the minimum.
lower control arm bushing is not difficult to swap imho...
Jamie
Old 01-12-2007, 01:28 PM   #3
bluesubie
Member#: 767
04 FXT
Same leak happened on my wife's 99 OB Ltd. That car was under warranty though and we also had them replace the timing belt.
-Dennis
Old 01-12-2007, 09:31 PM   #4
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
recommended:
at the minimum.
Jamie
Great minds think alike:
http://www.forumsubaru.com/showthrea...light=oil+leak
Looks like we gave him the exact same advise....
RexyGirl is offline   Reply With Quote
1999 Outback Limited - San Antonio TX m4ff3w Private Vehicle 'For Sale' Classifieds 0 09-06-2009 08:41 PM
1999 Outback Key Issue trueno16v Legacy Forum 10 03-02-2009 10:28 PM
1999 Subaru Outback Limited Wagon - FS Cheap! ChrisSK Private Vehicle 'For Sale' Classifieds 1 05-04-2008 09:40 AM
FS: 1999 Outback Limited drewdub Private Vehicle 'For Sale' Classifieds 12 04-26-2007 01:05 PM
1999 Outback Limited Bulb questions?? humdinger4u Electrical & Lighting 2 03-14-2005 04:33 AM
