![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 88501
BAIC
Vehicle:2006 WRX Wagon CGM |
Is there a chart or guideline as to what the optimal tread width to rim width is?
What I'm getting at is if the tread is narrower than the rim, then the sidewall would camber in from the rim edge (bead) and says you could have gone bigger (for more traction). If the tread is wider than the rim, then the sidewall will have to bulge out over the rim like a beer gut and the deformation reduces the effectiveness of the extra tire area. So there must a window of balance between diminishing returns. On the stock 06 17" wheel, it's 215mm vs 7". 215 millimeter = 8.464 inch so the stock tire is wider than the rim. Is this why 225 is already pushing it on the stock rim?
#2 |
Member#: 22412
SWIC
Vehicle:2012 Legacy 2.5GT Ice Silver Metallic |
People run 225s on the 16x6.5 rims which come one the 02-05 cars without too much fuss - why do you think 225 is pushing it on the 06/07 rims? Shouldn't be a problem at all.
As far as workable rim widths for a tire, on the tire rack site if you look at the spec table for a given tire, they show you the recommended rim width for each size. |
#3 |
Member#: 7958
Vehicle:09 GH B+ |
There is a "general" rule of thumb to use a rim width that is 90% of the tread width (not section width).
For a 225/50/16 tire- tread width varies but is usually in the 8.3" ish range= 90% is 7.47" or 7.5" Just a general rule of thumb ![]() |
| Thread Tools | |
| Display Modes | |
| Rim width min/max | Ace009 | Tire & Wheel | 0 | 03-23-2005 11:28 AM |
| Upsizing: Matching wheel width to tire width and adjusting offset | sonicblue | Tire & Wheel | 14 | 08-16-2004 02:28 PM |
| A question regarding max rim width for 18" rims for my 02 wrx wagon | davejread | Tire & Wheel | 0 | 06-16-2004 04:29 PM |
| Tire width and rim width numbers? Any resources? | ciper | Brakes, Steering & Suspension | 5 | 07-23-2002 10:43 PM |
| tread width vs section width? | WRXhauls | Brakes, Steering & Suspension | 2 | 06-13-2001 07:12 AM |
