Old 01-12-2007, 08:00 PM   #1
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
Default Changed Spark Plugs
I just changed my spark plugs. they were quite overdo for a change. I put in some Denso Iridiums this time. I had NGK Coppers one step colder installed before. They were pretty discolored. Haha. They were gapped out to .045 on all 4. I was probably blowing my spark out at high boost with that. Hence the missfire codes i had earlier this month. haha. Just wanted to throw that out there.
Rexwagon03 is offline   Reply With Quote
Old 01-12-2007, 08:17 PM   #2
Paulie V
Member#: 10260
2002 WRX Sedan
PSM- Knock, knock :-(
Yep, that would probably do it! How many miles did you have on them?
Paulie V is offline   Reply With Quote
Old 01-12-2007, 08:50 PM   #3
stblz
Member#: 137360
2004 wrx wagon
blue
Subaru Stars spark plugs
i was thinking of changing mine. is it a pain in the butt? whats the best plugs
stblz is offline   Reply With Quote
Old 01-12-2007, 10:19 PM   #4
Rexwagon03
Member#: 127429
i had like 20,000 on them. i have an 18G with supporting mods. I put off changing them, suppose to with the plugs i had like every 10,000.
Well its not that hard to change them but it does take some time and the right tools. It takes a bit the first time u do it, but after u do it once it will only take u have the time.
For plugs i guess it probably depends on if your still stock or are heavily modded. If you have a turbo upgrade and all the supporting mods then you probably gonna want to go with some high end plugs. I Got some Denso Iridium which are like 65 bucks for four of them. they last a lot longer too though.
Old 01-13-2007, 08:38 AM   #5
AlboWRX
Member#: 37719
2003 WRX
the best plugs are coppers. I use NGK BKR7E Stock # 6097. The only downside is you have to change them every year or 10k miles which is nt that bad. Something for me to do during summertime.
AlboWRX is offline   Reply With Quote
Old 01-15-2007, 12:35 AM   #6
Rexwagon03
Member#: 127429
yeah ive heard coppers are the best, but i havent really seen it published anywhere to say that.
Old 01-15-2007, 12:46 PM   #7
Swanny07
Member#: 86493
2013 WRX 5-door
I'd just throw the stock plugs in. It's not hard to change the plugs, just time consuming (if you've never done it before).
-Taylor
Swanny07 is offline   Reply With Quote
Old 01-15-2007, 06:25 PM   #8
Petersubaru
Member#: 134593
2001 Outback
I think the subaru stock plugs are copper with a platium tip..best of both worlds...
Petersubaru is offline   Reply With Quote
Old 01-16-2007, 03:52 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
There was alot of discussions on the denso iridiums in the wrx's regarding kernal blow out a few years back. I don't think it was anything definitive, but take a look if you start getting some stuttering or hesitation. Primarily this was on modded cars.
strohausii is offline   Reply With Quote
Old 01-16-2007, 09:17 PM   #10
Sushiplate
Member#: 121055
2005 Impreza WRX
OBP (with custom swirls!)
Is one step colder a good idea for stage 4 WRXs?
Sushiplate is offline   Reply With Quote
Old 01-17-2007, 08:16 AM   #11
tricarinate
Member#: 137717
the ngk g power spark plugs are best for your car.
tricarinate is offline   Reply With Quote
Old 01-17-2007, 11:25 AM   #12
AlboWRX
Member#: 37719
2003 WRX
Read the Spark Plug FAQ by Unabomber!!!
Old 01-17-2007, 04:32 PM   #13
Rexwagon03
Member#: 127429
yes they are almost a must
Changing spark plugs...need to change all 4? jester696 Service & Maintenance 6 12-22-2008 08:10 PM
Trying to change spark plugs - can't get socket on plug winston856 Service & Maintenance 5 03-18-2008 05:42 PM
changing spark plugs? racerwad Newbies & FAQs 7 10-23-2000 06:47 PM
When did everyone first change spark plugs? SubieRacer Technical Forum Archive 19 05-27-2000 07:38 PM
At what engine temp to change spark plugs?? Dan00RS Technical Forum Archive 5 05-12-2000 12:52 AM
