Old 01-12-2007, 11:09 PM   #1
sc00ter
Member#: 117767
2015 WRX
CWP
Default low idling problem with new 02 sensor
I got my front 02 sensor replaced today under warranty. Now when I'm idling my RPM's stay around 100 RPM's with sudden jumps up to 400 RPM's. It feels like the car is going to stall when in neutral.
Is there any way to manually increase the car's idling RPM's, or is this a bigger problem??
sc00ter is offline   Reply With Quote
Old 01-13-2007, 06:08 AM   #2
Hayes
Member#: 11808
The computer controls the idle and there is no adjustment. I suggust you reset the Engine Control Modual by disconnecting the negative battery cable for about 1/2 hour and press the brake peddle several times for several seconds each time. This will reset the ECM and you should be fine. Dealer should have done this. Ed
Hayes is offline   Reply With Quote
Old 01-13-2007, 10:49 AM   #3
scooterforever
Member#: 55011
Yeah, if Hayes' suggestion doesn't do it, I'd immediately take it back to the dealer as "you touched it now..." But it does sound like it needs a reset.
scooterforever is offline   Reply With Quote
Old 01-14-2007, 05:46 PM   #4
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
+1, the car hasn't adjusted to the new sensor yet.
mike_b49431 is offline   Reply With Quote
CEL / low idle problem on STOCK 05 2.5RS 2.5impreza Normally Aspirated Powertrain 22 08-25-2014 06:57 PM
WTB: BNIB/Low mile/Lightly used rear 02 sensor for 07 WRX ThreeEleven Private 'Wanted' Classifieds 1 01-26-2010 03:45 PM
Low idle problem bryan04wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-13-2010 05:22 PM
low idle problem? GT11 Newbies & FAQs 5 03-09-2009 05:52 PM
Help, low idle problem Goofy's WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-27-2006 04:29 PM
