Old 11-25-2001, 09:13 PM   #1
baldcherub
Member#: 11017
1998 L
Default 2.5 RS vs 2.2 L
I have read in a thread (I forgot which one) that a stock 2.2 L can keep up with a stock 2.5 RS if driven correctly... is this true? and what exactly does driven correctly mean???
baldcherub is offline   Reply With Quote
Old 11-25-2001, 09:43 PM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Ummmm no.
If the RS has a bad driver and the L has a perfect driver maybe...
Midwayman is offline   Reply With Quote
Old 11-25-2001, 10:21 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
john wasn't too far behind me in his L wagon at our last rally-x but he has more expereience in the dirt then i did. But sure there's a chance...given the right (or wrong) drivers.
jeremy
Old 11-25-2001, 10:23 PM   #4
baldcherub
Member#: 11017
1998 L
that's what I thought but I looked up the 0-60 times on the L and the RS and they differ by about 0.4 seconds... is that a lot? I mean for the extra amount you pay for the RS?
of course I'm ignoring the other factors such as the LSD, the improved looks and suspension etc...
but I'm talking about pure 0-60 time
plus the compression ratio on the RS is a tad too high for turbo isn't it?
Old 11-25-2001, 11:18 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
In my opinion, 0.4sec in 0-60mph is easily within the good driver vs. bad driver range.
Go tell that to all the guys in the Aftermarket Forced Induction Forum. With good fuel and engine management, guys are running boost pressures in the double digits.
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 11-25-2001, 11:26 PM   #6
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Aint no way!! even with a lousy 2.5 driver.Ive owned both.That .04 has got to be BS.Im talkin staight line here,,not threw the twistys and what not.There the driver would count.
Rudy
jagcars26 is offline   Reply With Quote
Old 11-26-2001, 02:40 AM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
No
Unless you take alot of weight out of the 2.2 and leave that same weight in the 2.5
Its 140hp vs. 165hp
Old 11-26-2001, 09:09 AM   #8
inpreza kid
Member#: 3334
when i drove a 140hp L i noticed it had alot less torque and power. i think it might be a little more than .4 seconds. than again it might be just my butt dyno.
inpreza kid is offline   Reply With Quote
Old 11-26-2001, 09:42 AM   #9
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
don't forget the ABS!
ok, so it's not always the best thing...but generally it is better to have it, than not.
JGard is offline   Reply With Quote
Old 11-26-2001, 11:16 AM   #10
baldcherub
Member#: 11017
1998 L
ok I did more research...
the fastest time I found for a 98 2.2 L is 8.8
the fastest I found for a 98 RS was 8.2
does that sound about right?
Old 11-27-2001, 09:47 AM   #11
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
i haven't seen the 98's times, but that could be right.
I know it has a different engine than the 99-01's, with less torque. The best I've seen on a 99-01 RS 0-60 is 7.7 seconds, as reported by SCC.
Old 11-27-2001, 02:29 PM   #12
advance
Member#: 3291
Driver makes the differce, I have beaten RS's before and I am completely stock other than looks and I ran a 16.5 1/4 mile grinding third really bad which means I should have been around 16.4 or 16.3, they can keep up, on the freeway or on the drag but the RS seems to respond better in 4th than my car.
advance is offline   Reply With Quote
Old 11-27-2001, 04:48 PM   #13
joltdudeuc
Member#: 6119
1999 GM6
RBP
i can do 0-60 in 7.8 in my RS...
Intake Silencer Removed
Stromung Mild-Steel Midpipe
Stromung Dual Tip Exhuast
k&n panel Filter
SCC got 6hp across the board with the dualtip exhuast...
so, i figure i'm running 170hp... and i'm a pretty skilled driver, for the most part...
i don't think a 2.2 DOHC has the torque to keep up with a 2.5...
-Gagan
PS: there are some crazzzzzzzyy 2.2 out there though!!
joltdudeuc is offline   Reply With Quote
Old 11-28-2001, 12:13 AM   #14
baldcherub
Member#: 11017
1998 L
ohh those quarter mile times are pretty decent... although I got a 98 and stock you got about 5 more hp... don't know if that makes a big difference??? Right now I'm running a ractive muffler (4 1/2 inch tip) and larry ganz's cone filter conversion (which is quite nice with some custom fabrication may I add).... I'm getting a new clutch next week and putting it in myself (gonna kill myself doing it too probably but I'm not gonna pay someone 500 bucks to put it in for me)... then I'll take it to the track and see what it has...
hopefully the clutch will do something for me
Old 11-28-2001, 02:51 AM   #15
lethargicman
Member#: 8961
2001 Impreza GM6
Rest In Peace. 2/01-10/04
But remember, the 2.5 is just a bored and stroked 2.2. Top speed is very similar. The 2.5 simply has the advantage of the low-end. RallyImprezive (Impreza L 2.2 automatic) and I went at it once just to see. He kept up with no problem, granted he has an automatic, and my shifting was short and smooth. But I DID get him on the get go and stayed ahead. But he was on my ass the whole time. I for one have faith in the little 2.2's Still better than a Honda 1.whatever!
-Jason SDC
Huh huh, I said stroked!
lethargicman is offline   Reply With Quote
Old 11-28-2001, 02:55 AM   #16
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
And the 2.0 is just a bored, redone 1.8
Old 11-28-2001, 01:07 PM   #17
FlooredSubaru
Member#: 10254
1995 Impreza Rally
red with 2.0L turbo motor
i have beat 2.5rs in my modified OBS but i have also beat WRX who dont know how to drive about a week ago i beat one becouse he would shift at about 3500 rpm and the turbo didn't have much time too spool.
but my friends rock me in the 2.5 rs and if i had the money i would be driving one right now.
so if i was going to spend the money and had more time to save i would for sure buy the 2.5rs over any subaru L or at least the OBS becouse you get all the power stuff
Erik s.
FlooredSubaru is offline   Reply With Quote
Old 11-28-2001, 01:49 PM   #18
Iowannaski
Member#: 8268
00 GM67
BRP me ASAP
top speed for the L and RS are probably closer than they should be because of all the aerodynamic trash the RS has to deal with.
"just a bored and stroked 2.2"
well, yeah, I suppose more displacement does have something to do with the additional power
Iowannaski is offline   Reply With Quote
Old 11-29-2001, 05:45 AM   #19
damianq
Member#: 5380
1999 Impreza
Primer
Default If one takes the driver out of the equation
It is very possible that the 2.2L can be just as fast (0-60) as the 2.5L motor. The advantage that most 2.2L equipped cars have is weight. Most do not have a sunroof or power options, etc. The RS even has thicker sound deadening material and more of it. The seats are even heavier. It also has smaller & lighter rim/tire combination that allows it to accelerate faster, all things being equal.
Another advantage the 2.2 has over the 2.5 is that it makes its peak torque lower in the rev band than the 2.5. The 2.2 has a compression ratio of 10.0:1 and the RS has a 9.7:1 ratio. Therefore, upon launch, it reaches its peak faster than does the 2.5 which gives it a slight edge. The 2.5 catches back up w/ a higher revving engine so it can go further into the revs than the 2.2L allowing it to have a rolling advantage. Once moving the 2.5 will have more in reserve since the 2.2 will move past its peak and into inefficiency sooner than the 2.5L. The 2.5 can keep accelerating faster b/c it has more wind left in its sails.
Just to clear some things up:
Yes, the 2.5 is a bored & stroked 2.2L motor. The 2.0L motor is NOT a bigger 1.8L. They share the same design layout but internal passages & lengths are completely different. They are in the same family only by series not by manufacture. One was built to be a turbocharged engine from the get-go. The Japanese 2.0L motor is the most efficient Subaru has ever made. That cannot be said for the older 1.8L, any way you look at it.
Before anyone asks, I don't work for Subaru. Well, not exactly.
damianq is offline   Reply With Quote
Old 11-29-2001, 07:49 AM   #20
baldcherub
Member#: 11017
1998 L
ok according to edmunds a 98 2.2 L weighs in at 2720
and a 98 2.5 RS weighs in at 2825
which for the nonmathmeticians out there amounts to 105 pounds of difference.
not really... the 98 models both reach their peak torque at 4000... you must be thinking of the 2000 models which have the higher compression ratio and reaching it's peak torque at 3600. Giving it a 5 hp boost over it's predecessor.
just my two cents
Old 11-29-2001, 10:30 AM   #21
inpreza kid
Member#: 3334
i believe the MY00+ phase 2 ej 25's all have a compression ratio of 10.0:1 the MY99 and MY98 had 9.7:1.
Old 11-29-2001, 12:01 PM   #22
damianq
Member#: 5380
1999 Impreza
Primer
You are both correct but driving them you will see that they drive very similarly. The powerdand is very similar & and difference is almost undetectable, w/ the 2.2L.
Legacy 2.5 GT vs. Impreza 2.5 RS beantmt Newbies & FAQs 1 06-06-2007 04:05 PM
2005 2.5 RS vs. 2006 2.5i Paraskass Normally Aspirated Powertrain 15 08-18-2006 03:48 AM
('93-'01) 2.5 rs vs si vs rsx-s vs gs-r scoobyimpreza Impreza Forum 79 11-08-2002 12:30 AM
ROAD TEST: 2001 2.5 RS VS 2002 2.5 RS WantaSubaru Normally Aspirated Powertrain 4 06-11-2001 09:05 AM
