Old 01-13-2007, 03:06 PM   #1
mustangtx63
Member#: 78506
Default Fellow detailing Gurus! I need your opinion!!!
Unfortunately, my car came equipped with painted on pinstripes from the dealership. At first I did not mind them, but over time they have begun to irritate me. The pinstripes are not ugly, don't get me wrong, but they just do not belong on a wrx.
So in my valiant search for an effective and unharmful method of removal I found this. Apparently a bunch of guys over at the Lexus boards do not like the pinstripes that the dealer put on their cars. This method seems to work fine for them and supposedly will not harm the finish.
I just wanted everyone's opinion on this method and if you thought it might be safe to attempt.
Thanks guys.
mustangtx63 is offline   Reply With Quote
Old 01-13-2007, 03:21 PM   #2
Deuce_04RS
Member#: 104767
2004 Impreza 2.5RS
I don't know much about that method. When I removed the pinstripes on my '04 I just borrowed my sisters hair dryer, heated it up and started rolling it off with my thumb. Worked out quite nicely. Afterward I followed it up with some "Goof Off" to clean up the adhesive residue.
Deuce_04RS is offline   Reply With Quote
Old 01-13-2007, 03:41 PM   #3
ultraspdWRX
Member#: 115291
2003 MBP WRX
COBB Stage II
if you happen to have a buffer, they should buff right out. or a pinstripe remover wheel (basically like a rounded/circular pencil eraser) that you put on the the end of a dremel or drill.
ultraspdWRX is offline   Reply With Quote
Old 01-13-2007, 03:42 PM   #4
mustangtx63
Member#: 78506
The pinstripes you described removing were probably just the stick-on kind.
The ones on my wrx are painted on.
Old 01-13-2007, 03:43 PM   #5
mustangtx63
Member#: 78506
Nope, I do not have access to a buffer.
From what I've read, the removal wheels only work on the stick-on type.
Old 01-13-2007, 03:45 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Mustang,
I don't have an answer for you since I've never been in your posistion. However, a quick Google search revealed that even the oven cleaner method could have undesirable results. .....and I don't know if wet sanding/compounding would be a good idea either if you don't have experience. Personally, I would consult with a few professional detailers and/or body shops and get their 2 cents. Another option is to check out the forums on www.autopia.org for advice.
Kean is offline   Reply With Quote
Old 01-13-2007, 03:55 PM   #7
mustangtx63
Member#: 78506
Originally Posted by Kean View Post
Mustang,
I do understand that this method is risky and can potentially harm the paint. I did not think about autopia, though. I will ask there as well.
Old 01-13-2007, 05:41 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
...yeah. I figured since a lot of detailers (pro & amateur) hang around there, it's worth a shot.
Old 01-15-2007, 02:26 PM   #9
srad711
Member#: 12282
2004 STi silver
I would personally wet sand them off. take your time and u should have no problem.Keep It very wet and use a small rubber 3m squeegee as your back to the sand paper.
srad711 is offline   Reply With Quote
Old 01-15-2007, 06:54 PM   #10
mustangtx63
Member#: 78506
This is probably what I will wind up doing. I think I will get a quote from a professional detail shop so I don't screw it up myself.
Old 01-15-2007, 07:18 PM   #11
Vew
Member#: 74229
2004 PSM WRX
... are you SURE they're painted and is not a vinyl? You'd be surprised. It just doesn't seem like a likely thing for a dealership actually paint the stripes on.
Vew is offline   Reply With Quote
Old 01-15-2007, 07:31 PM   #12
mustangtx63
Member#: 78506
I am 100% sure.
The dealer has a company that paints pinstripes on their cars.
Old 01-15-2007, 07:56 PM   #13
Frshtrax
Member#: 84374
2005 WRX Wagon
Black Pearl
don't have an good answer, but these guys might help.
autopia.org
Frshtrax is offline   Reply With Quote
Old 01-15-2007, 07:58 PM   #14
mustangtx63
Member#: 78506
autopia.org
Been there. Some have done the oven cleaner method with some success but unkown affects on the paint. Some reccomend the wet sanding approach, which is most likely what I'll try.
Old 01-15-2007, 08:10 PM   #15
Frshtrax
Member#: 84374
2005 WRX Wagon
Black Pearl
That probably your best approach.
If you do wet sand it, start with a high grit paper. say 800 or so. you don't want to take any excessive subaru paint with it. These cars have a very thin paint job.
Old 01-16-2007, 09:56 AM   #16
ShiroChanWRX
Member#: 60542
2004 WRX SportWagon
I would be very careful putting something as caustic as oven cleaner on the very poor quality factory paint that subaru uses.
gentle wet-dry may be the way to go.
d
ShiroChanWRX is offline   Reply With Quote
Old 01-16-2007, 01:40 PM   #17
Vew
Member#: 74229
2004 PSM WRX
I am 100% sure.
ouch, sorry man
Old 01-16-2007, 06:01 PM   #18
mustangtx63
Member#: 78506
Thanks for all your help and opinions, guys.
Old 01-16-2007, 07:44 PM   #19
EnterTheDragon
Member#: 6511
wetsand with a very very fine grit followed by a polish to clean up the marring.
Use some 3m painters tape along side the edges of the pinstripes to minimize sanding where its not needed.
EnterTheDragon is offline   Reply With Quote
Old 01-16-2007, 08:02 PM   #20
mustangtx63
Member#: 78506
How fine of grit would you reccomend?
Old 01-16-2007, 08:12 PM   #21
EnterTheDragon
Member#: 6511
start off with as fine as you can, if that doenst work you can step it up from there.
it all really depends on the quality of the pinstripe really.
Old 01-16-2007, 08:14 PM   #22
mustangtx63
Member#: 78506
Awesome. Thanks for the info.
Old 04-20-2007, 12:20 AM   #23
RSTimpreza
Member#: 144808
2003 WRX
Sonic Yellow
god damn pinstripes!!!!!!!!!!!!!!!!!!!
RSTimpreza is offline   Reply With Quote
Detailing Guru's.....I need your opinion. KenSekiguchi Car Care & Detailing 6 02-09-2009 08:23 PM
Modifying Car gurus...need your opinion The Blue Pilot Off-Topic 56 12-19-2007 05:05 PM
IT Gurus I need your advice and opinions. ChosenWon Off-Topic 36 10-27-2003 08:34 PM
Digicam gurus, I need your appraisal sjt Off-Topic 2 09-08-2003 01:52 PM
Fellow I-Clubbers, I need your help!! Bohanan @ work General Forum Archive 16 07-27-2000 08:47 PM
