Old 01-13-2007, 07:32 PM   #1
subydude22
Member#: 108043
97 legacy outback
navy
Default intercooler question for my legacy
im building a 2.2turbo for my obw. I am definately going to add an intercooler but I dont know whether or not to get a tmic or an fmic if they make one for the legacy. what do you all think.
trevor~
subydude22 is offline   Reply With Quote
Old 01-13-2007, 07:50 PM   #2
morrocco88
Member#: 104098
1997 LGT 2.1 stroker
Rotated S200SX-56 6speed
What year OBW? If you are looking for cheap, you could always use a stock wrx IC, but how much power are you shooting for, as this could hold you back. I have an 03 wrx cooler on my 97 legacy, but I'm in the stock wrx power range. I had to do some trimming to get it to fit, but it can work and the price was $75 used compared to hundreds of dollars for a new aftermarket unit from a variety of companies.
morrocco88 is online now   Reply With Quote
Old 01-13-2007, 08:13 PM   #3
subydude22
Member#: 108043
97 legacy outback
navy
thats the same thing I was thinking. I was gonna try to find a stock wrx ic but I didnt know if some company made fmic for them. my car is '97. im not shooting for high power. something similar to a stock wrx, maybe a little bit more.
Old 01-13-2007, 08:29 PM   #4
ten80
Member#: 53625
00 EJ205 LGT LTD
97 LGT Wagon
I have a forester intercooler + bov + hoses I'd part with for cheap!
PS. there are lots of factors that come into play for optimum power. A properly tuned engine can make good power on even a small intercooler. My friend's V2 EJ20G swap made 249whp (~5000ft elevation) on the stock, tiny, JDM intercooler. We were in the process of installing a FMIC, however, it was too much of a pain in the rear and we went back to stock . I'd guess that a forester/wrx oem intercooler is good for up to somewhere near that power range, which is nearly impossible to attain with a TD04 or VF8 turbo.
ten80 is offline   Reply With Quote
Old 01-13-2007, 08:53 PM   #5
morrocco88
Member#: 104098
I'm running the stock EJ20G from an auto tranny JDM legacy, and it has the VF10 turbo. I couldn't get past 13 psi before it was making more heat than power. Is the TD04 larger than the VF10?
I would go for the top mount since it is easier, and think that you would have less lag for a street car, but maybe I'm wrong. Maybe someone who has had both can chime in on this?
Old 01-13-2007, 09:44 PM   #6
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Go for the TMIC. It's simpler and you can use a bunch of different OEM setups. I've got a WRX IC on my 98 Legacy - hard to beat OEM reliability too.
jey is offline   Reply With Quote
Old 01-13-2007, 11:53 PM   #7
rougeben83
Member#: 115154
2003 Legacy L Turbo
How much boost are you planning to run? For a low boost application (like less than 1 bar), the WRX intercooler is plenty fine; it also reduces pressure loss since the IC is right at the TB, and helps the pressurized air get into the engine quicker (less tubing it has to travel).
A FMIC would only be worth it if you're going to be boosting that engine above what a WRX engine does (14psi), or you're in a lot of stop and go traffic in hot,hot weather and worry about heatsoak.
rougeben83 is offline   Reply With Quote
Old 01-14-2007, 09:20 AM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Obviously your OBW has a hood scoop already which you can open up?
FWIW I have both a WRX and STi top-mount IC’s FS including all hoses & lines…
xcntrk75 is offline   Reply With Quote
Old 01-14-2007, 09:59 AM   #9
ten80
Member#: 53625
00 EJ205 LGT LTD
97 LGT Wagon
Sorry, I should have elaborated. TD04's are the stock turbos on WRX's and are really very small. I beleive that kbahus, my friend, is running VF10 and he made maximum power somewhere near 18psi. IMHO, FMIC, unless done right, results in lag, heat soak through long pipes, poor air flow, a PITA installation, weakened bumper beams, and the potential for excessive front-end accident damage. I'm all for TMICS, using hood scoops and the apropriate splitters.
xcntrk75, we'll have to thumb-wrestle or something for the sale
Old 01-14-2007, 02:28 PM   #10
rougeben83
Member#: 115154
2003 Legacy L Turbo
IIRC TD04 is good up to around 16-18psi before it starts choking on itself.
Also, it's better to match your turbo to the displacement of your engine; that is, if you actually want a driveable, fast car, rather than a dyno-queen that you can brag top end HP numbers with.
A TD04 is a pretty good match for the 2.2l, should give you a nice torque curve and little lag.
Old 01-14-2007, 07:13 PM   #11
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Might want to note that on the BD/BG model, the STi top-mount is really the largest IC that will fit under our low hoods. I ran a sti tmic on mine and it still rubbed all over the place. Sometimes front-mounts are unavoidable especially when considering turbo cfm.
But I agree, a 2.2l with a sub 500cfm turbo, TMIC FTW!
2 questions about my legacy wagon Zac86 Newbies & FAQs 1 10-29-2008 05:50 PM
Some questions about my Legacy Brighton kennyc Legacy Forum 8 02-22-2008 11:51 PM
a couple questions about my legacy steamboat26 Newbies & FAQs 4 01-06-2008 08:03 PM
STI intercooler question...for BD legacy malstew Legacy Forum 2 03-26-2007 04:35 PM
Intercooler question for my fellow desert dwellers Wrekaro South West Impreza Club Forum -- SWIC 3 04-28-2005 10:23 PM
Message Board Statistics All times are GMT -4. The time now is 08:10 PM.
