Old 01-13-2007, 07:43 PM   #1
xblaze1one
Member#: 123395
Midnight Black Pearl
Default beginner ?
I have been reading quite a bit on diy tuning and have a general idea on tuning theory. I'm a bit low on money right now and can't afford a wideband setup. I already have an egt gauge and have a tactrix cable on the way. My question is, do you think that i can get away with flashing a stage 2 XPT map or a cobb map ( note: i have tbe and up ) without a wideband? I really don't have the money for it, plus i would rather gain some more tuning knowledge before tinkering with my ecu. I figure it would be based on the same concept as the flashing with the AP, i don't remember anyone saying that you need a wideband to use it.
xblaze1one is offline   Reply With Quote
Old 01-13-2007, 11:01 PM   #2
Cheveyboy
Member#: 34773
2013 WRX STi
Your playing with fire then, tinker with pulling logs and using the software. While saveing 200 bucks for a LC-1 Wideband. This will keep you busy for a while, plus you will learn whats about what is going on. By the time you have some dough for a wideband you should be have the jist of whats going on.
Using someone else's maps are a great starting point, but they still will need to be tuned to your car in the long run.
Im going to leave your AP comments alone for now I dont want to get flamed, nor do I want you to get flamed
Cheveyboy is offline   Reply With Quote
Old 01-14-2007, 09:31 AM   #3
xblaze1one
Member#: 123395
thank for the info maybe i will just do that. I have a couple book on tuning coming to. I do have another question about the wideband though, which o2 sensor do i replace to get the reading the front or the rear sensor, Also will i through a cel with it? Where does the lambda cable connect to?
Old 01-14-2007, 09:56 AM   #4
Cheveyboy
Member#: 34773
2013 WRX STi
The new wideband sensor does not replace any of your existing sensors, you ECU still needs them. The new sensor will require a bung to be welded in to the exhaust after the turbo and before a cat. A exhaust shop would be able do this for you probley for 20 bucks or so.
Old 01-14-2007, 09:58 AM   #5
Cheveyboy
Member#: 34773
2013 WRX STi
Oh yea, the LC-1 comes with a serial cable that plugs into your laptop to do your logs.
beginner mods? Shaft0rz Normally Aspirated Powertrain 20 02-26-2002 07:02 PM
Autox - a beginners guide Petrie Vancouver Impreza Club Forum -- VIC 12 04-30-2001 01:00 AM
Mods for a beginner Poseidon Normally Aspirated Powertrain 7 03-23-2001 12:21 AM
Safety Gear for Beginner Auto-X/Driving School Ginseng Motorsports 7 03-03-2001 12:09 AM
Beginner Autocross events Ru fan New England Impreza Club Forum -- NESIC 8 01-30-2001 12:42 AM
