Old 01-13-2007, 10:09 PM   #1
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Default Water pump gasket failure
So the gasket on my water pump failed and it drained all of my coolant while i was driving down the rd.
It sucked, luckily nothing really bad happened, but now i'm in the middle of tearing it all apart. Instead of dealing with another gasket i'm going to use a high temp silicone sealant on it - let it cure for 48 hours and put it all back together.
~Mike
pilfflip is offline   Reply With Quote
Old 01-13-2007, 10:14 PM   #2
ten80
Member#: 53625
00 16' FXT
FYI, the gasket is a whopping ~$3.00 at the dealership. RTV is good stuff, however, I'd stick with a new gasket since they so rarely go bad and RTV is unproven in this application (I've never seen it used). You're damn lucky that you didn't overheat!
ten80 is offline   Reply With Quote
Old 01-14-2007, 09:08 PM   #3
pilfflip
Member#: 40484
'02 Murdered WRX
'02 Silver Legacy
Yea, i'm not sure why but it didn't affect the operating temp at all, I didn't even know something was wrong until it stopped spitting out warm air.
~Mike
Old 01-14-2007, 09:57 PM   #4
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
I would go with the OEM gasket if I were you!
dplacen is offline   Reply With Quote
Old 01-15-2007, 12:54 AM   #5
NiTRoN
Member#: 30556
2000 Legacy GT (BE)
over 250,000 Miles
hell i would swap out timing belt as well while ur at it.. after all u have to take it off to get into there..
NiTRoN is offline   Reply With Quote
Old 01-15-2007, 06:19 AM   #6
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
Same thing happened to my legacy and i used permatex brand "right stuff" to seal the new pump. It's been just fine for at least 10k now.
MCarp22 is offline   Reply With Quote
Old 01-15-2007, 08:41 AM   #7
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
I use the OEM gasket plus RTV, on both sides of it. I did my water pump on my Legacy over 44k ago and it hasn't leaked a single drop.
DerFahrer is offline   Reply With Quote
Old 01-15-2007, 10:00 AM   #8
ten80
Member#: 53625
00 16' FXT
Definately shouldn't leak but may be a PITA to remove some day I've found that the super nasty gasket remover goop from NAPA does the trick.
Old 01-15-2007, 06:42 PM   #9
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
I have installed many water pumps and never had a problem with the OEM gasket.
Old 01-15-2007, 07:12 PM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
As long as you're in there, do the works, timing belt, water pump, etc.
Wiscon_Mark is offline   Reply With Quote
Old 01-15-2007, 08:50 PM   #11
dplacen
Member#: 117010
1997 Legacy GT
2006 Spec B #256
^ +1 He is right!
Old 01-15-2007, 10:32 PM   #12
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Not only that but it's likely the pump has failed (seized up) which may have caused excess pressure on the housing and therefore gasket leak. I've never heard of one leaking that badly, that quickly b4...
xcntrk75 is offline   Reply With Quote
FS 02 WRX Parts: Short block, TD04, oil pump, water pump, gaskets, injectors, etc. Ryan314 Engine/Power/Exhaust 13 05-15-2010 11:53 PM
FS 02 WRX Parts: Short block, TD04, oil pump, water pump, gaskets, injectors, etc. Ryan314 NESIC Private Classifieds 6 05-13-2010 09:35 PM
FS: ej25 water pump/cam seals/oil pump seals/timing belt cover gaskets sti charles Engine/Power/Exhaust 24 11-02-2008 02:10 PM
Leak at Water Pump Gasket ITWRX4ME Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-21-2006 09:58 PM
Leaky Head Gasket & Water Pump Gasket - MY00 Forester lark6 Normally Aspirated Powertrain 20 11-10-2001 10:22 PM
