Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-14-2007, 12:36 AM   #1
F4tune
Member#: 126800
1990 Subaru Legacy
Default 2.5L/2.2L running problem
So from this link you will know which engine and spec I'm talking about. http://forums.nasioc.com/forums/show....php?t=1107352
The engine started but ran a little rough the other day. I had swapped the original Aux air valve and figured that was the problem. The engine went from 1000rpm to 2000rpm reving up and down and stopped then did run for a little bit once warmed up. So I put on my original valve. The engine runs smooth after starting goes up to about 1500rpm and then to 1000 and dies. I can start it again but it does the same thing, like running out of fuel although it smells from the exhaust that it's running to rich though. I did see I had missed a plug to the small air box under the intake manifold on the left viewed from the front. So I plugged it in but the same problem. Any clues guys? I've checked all the plugs and pipes and all seems in order. The 2.2L ran sweet before I did this conversion.
The engine sounds fine with no odd noises.
To me it's like it's to cold and not getting enough fuel even though it smells rich. Tomorrow I'm going to pull the plugs to see what's happening in there.
F4tune is offline   Reply With Quote
Old 01-14-2007, 10:23 PM   #2
F4tune
Member#: 126800
1990 Subaru Legacy
Okay the story so far. I've fiddled with the Aux air valve and I'm almost sure this is working good. I did move the throttle sensor box a little which did seem to help and the engine did rev a little better. The engine spits back through the intake which I thought at first because it was cold but when I got it hot it still did the same thing. In fact when trying the rev the engine it's holding back and some times clear out and revs a little better
Now at with the conclusion the timing belt has slipped or I screwed up when setting the timing.
The worst thing is the smell from the exhaust, it makes your eyes water. So I feel this is unburnt fuel due to the timing.
Tomorrow I will pull the timing covers.
Thanks
Old 01-15-2007, 11:48 PM   #3
F4tune
Member#: 126800
1990 Subaru Legacy
O2 sensor faulty and ECU needed to reset it's self. Engine ran today for 45mins. Just need to replace the header and system and I should be ready for a road test.
Old 02-14-2007, 04:50 AM   #4
DaGamer
Member#: 88723
My00 Impreza RS
BRP
very interesting keep us/me updated =D!
DaGamer is offline   Reply With Quote
Subaru Impreza 97-05 2.5l 2.5rs 2.5 Rs Header alysssaa Engine/Power/Exhaust 10 04-23-2010 02:33 AM
Subaru Impreza 97-05 2.5l 2.5rs 2.5 Rs Header alysssaa SWIC Private Classifieds 0 02-16-2010 11:47 PM
2.5L/2.0L hybrid - Which flywheel/clutch do I need? vin0305 Transmission (AT/MT) & Driveline 3 10-16-2008 01:01 AM
2.5L/2.2L build F4tune Built Motor Discussion 30 09-20-2007 04:34 AM
Borla 2.5L/2.2L Headers: So CAL 555subaru Engine/Power/Exhaust 2 05-14-2007 02:01 PM
