Old 01-14-2007, 11:54 AM   #1
chokin
Member#: 124739
02 wrx
black
Exclamation Car won't start
guys...i was at a store and the car was idling and i saw my dash light(every light, the very tiny headlight at the coner) was kinda flashing ....but i didnt know what happened...so i turned off and try to start it ...but it wont start..and the engine crank( click sounds) tho ...so i had my friend jump it for me...it started. i went back where i work and i thought the battery died ...so i diconnected it and took it to checker and have them do the battery check and they said the battery was fine and charged the battery ...they said should be the alternater. so i went back and hook up the battery, but these time it wont start neither and there wasnt any "click" sounds,so i had dave cam over and he pushed and start the car, the car started right after. according to this case, whats wrong with my caR??? battery??alternater, starter and something else??
the worst thing is the car wont start, so i cant bring it into any shop to fix
chokin is offline   Reply With Quote
Old 01-14-2007, 05:44 PM   #2
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
Something with the starter maybe??? Maybe a bad ground from your battery, no really sure, but something to check.
mike_b49431 is offline   Reply With Quote
Old 01-14-2007, 08:22 PM   #3
eb1888
Member#: 115226
2005 wrx wagon
Can you start it with a jump still? If so it may still need a new battery, but it seems more likely its poor contact between the cables and the battery terminals or the cables and the starter or negative ground connection. Clean them. Have someone crank it while you move each cable. There may be corrosion between the cable and the cable end. Cables need to be replaced eventually, they wear out like batteries.
eb1888 is offline   Reply With Quote
Old 01-15-2007, 12:50 AM   #4
chokin
Member#: 124739
02 wrx
black
no it wont jump start ...but only push start tho ..ok ...i will try to clean the cable...
Old 01-15-2007, 02:23 AM   #5
tac04wrx
Member#: 120791
2014 xv
dk
yeah +1 for battery.
this just happend to my friend last week. same exact thing. its cranking but not starting...and lights are flashing. we jumped it switched the battery and everythign was ok.
tac04wrx is offline   Reply With Quote
Old 01-15-2007, 10:04 AM   #6
chokin
Member#: 124739
02 wrx
black
but CHECKER ( parts store ) checked my battery and said the battery was good ....tho ...after i hooked up to my car...it crank once..and wont start...not even start when i jump it tho ..
Old 01-15-2007, 11:40 AM   #7
Hayes
Member#: 11808
If the battery was not checked under load, then it is the battery.
Hayes is offline   Reply With Quote
Old 01-15-2007, 12:21 PM   #8
chokin
Member#: 124739
02 wrx
black
they didnt tell me the battery was under load or not
Old 01-15-2007, 04:00 PM   #9
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
how old is the battery?
Old 01-17-2007, 08:17 AM   #10
tricarinate
Member#: 137717
I think your battery is the source of this problem.
tricarinate is offline   Reply With Quote
Old 01-17-2007, 08:22 AM   #11
bigboss
Member#: 109828
03 WRX wagon
Sonic Yellow
Replace your battery. Pretty much all of your symptoms point to that.
bigboss is offline   Reply With Quote
washed engine bay, now car won't start CEL on pinoy_boy204 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 06-08-2010 09:12 AM
Fuel pump won't start, blown fuse SBF 2, car won't start ClassicGC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-29-2008 09:18 PM
Car won't start - cranks but won't start dave_88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2007 10:29 PM
Car won't start, but won't turn off BigBlueSVX Legacy Forum 4 08-22-2007 10:23 AM
Car won't start. Won't crank, but lights will turn on Gorge Service & Maintenance 9 01-09-2007 01:23 AM
