Old 01-14-2007, 12:38 PM   #1
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Default Let's get Mark some better brakes!
Okay, so I can't fit WRX brakes under my 15" stockers. Right now I have two sets of rims and tires, my stock outback rims with some hydroedge tires on them (they have to go, they're awful and have a lot of miles on them) and then my winters are on a set of steelies.
I would be willing to look for some WRX rims for summer and switch to my stock outback rims for winter (keeping my XIce tires, they rock) if the steelies wouldn't work out for some sort of upgrade because I know steelies usually have less clearance than alloys.
Anyways, what would be an upgrade for me that would work with my rims? I know the BE Ls had 15" rims like mine at one point, but were they the same brakes? How about GC RS brakes?
I'm open to suggestions. Basically I'm looking at picking something up used because I can't afford to buy new rotors, pads, etc right now, but need something that isn't worn out (my rear rotors are warped, and the pads aren't gripping all that well anymore).
Wiscon_Mark is offline   Reply With Quote
Old 01-14-2007, 12:45 PM   #2
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
GC RS brakes will fit under the 15" alloys, as that's what came on OB's stock. WRX calipers won't, they're just a touch too big to clear with the 15's. I'm not sure about the steelies, though. The 96+ cars with the 2.5's came witht he same Legacy Turbo wheels as your car, and had RS/GT brakes front and rear.
If you want to seriously upgrade your rears, you could upgrade to a Legacy Turbo vented setup, and that will fit under your stockers, but you don't need much in the rear; I'm running my big Stoptechs in front and the rear is balanced fine with some semi-metallic pads and slotted rotors.
sybir is offline   Reply With Quote
Old 01-14-2007, 01:21 PM   #3
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
So you're saying that RS/Outback/GT brakes would be an upgrade for me (with what is essentially an L wagon)?
Old 01-14-2007, 01:30 PM   #4
that one legacy
Member#: 103665
from what i understand, that is correct. i think it was the '97 and up outbacks that had larger front brakes, as well as the '97 and up GT legacies. so if you can find one at a junk yard, see how much they want for the calipers and rotors off one.
what would be really cool is if you could get some RS rims, and swap in the 4 pots in the front.
that one legacy is offline   Reply With Quote
Old 01-14-2007, 01:32 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
haha, yeah, I'd love some RS rims, but they're not as cheap as WRX rims. And like I said, I'm not ditching my winter tires, too expensive to get a new set on 16s.
Old 01-14-2007, 01:35 PM   #6
that one legacy
Member#: 103665
oh believe me, i understand that completely. i was actually going to switch to RS rims from my Forester rims at one point, but once i realized how much it would cost even for a messed up set, i decided to put that money towards other things.
have you considered just getting more aggressive pads and stronger aftermarket rotors in your stock size? the real advantage to bigger rotors is better heat dissipation, not really in an actual increase in stopping power. you could get a set of brembo blank rotors, and some good front pads, and you'd be pretty good for quite some time.
Old 01-14-2007, 01:47 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yes, I have, but like I said, that's expensive. I'd rather just get a used set and add some decent pads (like Hawk HPS) to it. It'd be cheaper.
Old 01-14-2007, 02:22 PM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
RS front brakes are still 10.7" like the GT, and dual piston. Impreza L's got a single piston front brakes that used a smaller rotor, 9.x" I think. So basically, if you have a dual piston, highly likely you have GT brakes already. Good way to note the difference is whether you have 1 arch on the front your brake caliper or 2 (each arch denotes a piston):
If you can get the WRX brakes cheaper, I would go with those and upgrade to 16" anyway. The performance across the spectrum will be much better with the 16"s on top of the wrx brake upgrade. Otherwise, you can hit up RS25 once and awhile someone there sells off their stock RS brake setup real cheaply. I think I sold mine for around $65 shipped (with rusty rotors ) when I upgraded.
rougeben83 is offline   Reply With Quote
Old 01-14-2007, 03:30 PM   #9
95legacy
Member#: 74009
95 Legacy GT
Deep Sapphire Pearl
Interested in the Golds mark? I'm saying goodbye to them soon.
Peace,
Kyle
95legacy is offline   Reply With Quote
Old 01-14-2007, 04:46 PM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Peace,
Kyle
Yes
Thanks for the advice Ben, I think I may already have the two piston calipers, but cannot tell with my steelies on. My memory can be a fickle thing.
Old 01-14-2007, 05:23 PM   #11
that one legacy
Member#: 103665
i was under the impression that your car is basically the same as mine mechanically, which would mean 1 pots in the front, and much smaller 1 pots in the rear.
Old 01-14-2007, 05:24 PM   #12
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Probably, but the '95 Outback was a weird model. My dad's mechanic (the last person to do the brakes) may have slipped an upgrade in there too.
Old 01-14-2007, 05:36 PM   #13
MCarp22
Member#: 102684
2013 Impreza
Deep Cherry
I upgraded mine from the 14" wheel style 1 pots back when I got the car. Raybestos part numbers for the loaded calipers (that's fully assembled on the brackets with pads ready to bolt-on) are:
Left - RC10981
Right - RC10982
plus the matching brake rotors are:
96658
If you already have the 15" sized stuff, get some performance pads, like hawk HPS or something.
MCarp22 is offline   Reply With Quote
Old 01-14-2007, 06:05 PM   #14
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yeah, and I totalled up the cost and simply cannot afford new rotors and HPS pads. And I certainly don't want to cheap out and get Axxis or some junk like that.
Old 01-14-2007, 09:20 PM   #15
spdracr00
Member#: 65823
1996 Impreza L
Red
to bad you are so far away, there are two outback wagons being parted out on the local craigslist..
spdracr00 is offline   Reply With Quote
Old 01-15-2007, 12:27 AM   #16
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
The two-piston front caliper GC RS, Outback & GT brakes are very decent for normal daily driving and will accept 15" wheels (although they are too large for 14" wheels). Unless you are a very serious Auto-X or "Track" your car, I have serious doubts as to the need to use a 2001+ WRX brake setup. Going that route basically REQUIRES 16" or larger wheels.
The additional "unsprung" mass of the WRX brakes & larger wheel setup is hard to justify. The 15" Legacy "L" alloy wheels are durable and are much lighter than a 16" wheel setup. This to me seems like an ideal compromise.
Jonathan is offline   Reply With Quote
Old 01-15-2007, 12:36 AM   #17
Jonathan
Member#: 4021
1999 Legacy GT Ltd
The BE (third generation) Legacy weighs something like an 400 Lbs more that the BD (second generation) Legacy. The front brake setup was rather quickly found to be inadequate for serious mountainous driving duties. My understanding is that after the first year of the BE (2000) Subaru upgraded all the BEs to the larger 16" wheel setup so as to accomodate the larger, more powerfull brake setups.
Old 01-15-2007, 03:17 AM   #18
rougeben83
Member#: 115154
2005 Outback XT
White on grey
BE L for all years sold in North America came with the 10.7" brakes (I should know). BE GT's got the bigger WRX brakes starting in 2002.
Old 01-15-2007, 08:02 AM   #19
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
why upgrade your brakes if you're still on 15" stock wheels?
you could go with a WRX setup. use the WRX rotor + caliper bracket in the summer. When you swap wheels swap rotors and remove the caliper bracket.
easy as 1-2-3
iamrazor is offline   Reply With Quote
Old 01-15-2007, 10:38 AM   #20
ttatsumi
Member#: 85763
Why not a brake fluid upgrade and SS lines? I'm not too familiar with these things but I've read improvements unless you've done these already. New rotors calipers and pads will be tons of $$ i would guess unless you are willing to spend that cash.
ttatsumi is offline   Reply With Quote
Old 01-15-2007, 11:40 AM   #21
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Yeah i got 2 pots up front on my 97 BG. The calipers are the same on certain imprezas also. May wanna check around for a set if you dont already have 2 pots....
m.
vitai0 is offline   Reply With Quote
Old 01-15-2007, 12:31 PM   #22
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
i have a set laying around from my legacy mark. talk to me.
choung
illegal2.2 is offline   Reply With Quote
Old 01-15-2007, 01:59 PM   #23
iamrazor
Member#: 52324
2011 WRX LTD (FS)
1990 T30 miata
You could start with new high quality pads + fluid (a full bleed). That'll make a huge difference without breaking the bank.
Old 01-15-2007, 05:03 PM   #24
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
SS lines aren't cheap last time I checked, and not worth it to my stock brakes.
Since the rotors are warped, I HAVE to do that. I will bleed the brakes when I work on them. I'm just looking for a used upgrade that will be an easy fix until summer when I have the time to make some decent money.
Old 01-15-2007, 07:21 PM   #25
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
What about getting reason's parted out GT brake setup?
Plays_With_toys is offline   Reply With Quote
Let's get a list of aftermarket Impreza brake pads together. Butt Dyno Brakes, Steering & Suspension 5 04-05-2008 09:59 PM
Let's Get These Brake Sizes Out On the Table stimpy Brakes, Steering & Suspension 4 10-21-2002 09:51 PM
JDM Projector Owners: let's get some reviews no_rex_yet Interior & Exterior Modification 7 04-30-2002 08:57 PM
IHI VF Turbos, let's get some information flowing... Conduit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 51 11-07-2001 05:17 PM
