Old 01-14-2007, 09:02 PM   #1
rallymarty
Member#: 17418
2003 4Runner
Default Help with CEL...
I have a po440 CEL (evap. emiss. control malfunction) on my wife's '00 pontiac. i replaced the gas cap already thinking this was the culprit. no luck, the CEL is back. what else could be the problem?
rallymarty is online now   Reply With Quote
Old 01-14-2007, 11:01 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Maybe other parts of the evap. system? Charcoal cannister, valves/solenoids, etc. - check to see if any wires are broken, etc. - for specific diagnostic stuff, it really helps if you have the service manual for the car, though...
Old 01-15-2007, 08:19 PM   #3
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Whenever you have an evap code first place to check is the gas cap. Verify it is tight and reset light. If light comes back on with the same evap codes then the charcoal canister, purge valve, etc might be the culprit.
blackfang is online now   Reply With Quote
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 05:55 AM
need help with CEL slammedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-06-2002 01:16 AM
Help with CEL P0457 EVAP Sparks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-15-2002 11:35 AM
Help with CEL! WRXavier Service & Maintenance 3 06-26-2002 09:24 PM
Need help with CELs BluJay Tri-State Area Forum 3 11-03-2001 09:31 PM
