Old 01-15-2007, 12:32 AM   #1
oversteer
Member#: 14923
2007 Subaru turbo
Default 300whp with stock air intake. Anyone?
My STi has a 3" TBE and APS headers but even with a COBB Protune I can't hit the magic 300whp mark. This has me thinking that the stock airbox and panel filter might be holding me back a bit. Have any stock turbo STis hit over 300whp without some kind of air intake kit? How much power should I gain with the APS cold air intake?
oversteer is offline   Reply With Quote
Old 01-15-2007, 12:43 AM   #2
06blksubwrx
Member#: 109084
07 4EAT Forester
11.8 @115
An intake might help a little but your stock intake shouldn't be holding you back at only around 300whp on the stock turbo. Psi?
06blksubwrx is offline   Reply With Quote
Old 01-15-2007, 10:19 AM   #3
oversteer
Member#: 14923
2007 Subaru turbo
19psi peak with the VF39.
Old 01-15-2007, 11:41 AM   #4
STi*guy.kiev
Member#: 117854
2003 spec c
Should be 22psi...
STi*guy.kiev is offline   Reply With Quote
Old 01-15-2007, 11:51 AM   #5
CatfaceType-R
Member#: 81102
^^^no it shouldn't, that would be a pretty agressive tune...on race gas it would be fine
CatfaceType-R is online now   Reply With Quote
Old 01-15-2007, 12:02 PM   #6
STi*guy.kiev
Member#: 117854
2003 spec c
~11.3-11.4 AFR + 95% IDC = 300+whp (TBE catless, Walbro pump, EM)
Old 01-15-2007, 12:43 PM   #7
CatfaceType-R
Member#: 81102
that is a pretty agressive tune...while I am safe at 20psi, i'm not sure of my duty cycle but i know it's not close to full duty...i am at 255 whp on a mustang dyno (catless tbe, protuned)
Old 01-15-2007, 12:55 PM   #8
wrxxed
Member#: 20567
04 2014 Forester
each dyno reads differently,300 on one dyno may not be 300 on another
wrxxed is offline   Reply With Quote
Old 01-15-2007, 01:03 PM   #9
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
well by the looks of it, if you want 300whp at stage II you should have waited and got a 07....pump gas on a 04-06 will only get you into the 290's, if your lucky....me 288whp on a warm day on a dyno jet
blowbyu24 is offline   Reply With Quote
Old 01-15-2007, 01:03 PM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
This guy gets it....I like him!
Old 01-15-2007, 01:03 PM   #11
Lit Fuse
Member#: 81706
^^^yep. Take it to the track and see how your set-up does against other cars wih similar mods. I have learned that dyno readings are only about braggin' rights, nothing more.
Lit Fuse is offline   Reply With Quote
Old 01-15-2007, 01:03 PM   #12
Riight112
Member#: 32071
2004 WRX STi
WR Blue
bigger injectors and fuel pump? maybe a stronger wastegate actuator?
Riight112 is offline   Reply With Quote
Old 01-15-2007, 01:05 PM   #13
oversteer
Member#: 14923
2007 Subaru turbo
I know I know etc that all dynos read differently but to simplfy things has anyone made over 300whp with the stock airbox and a VF39 on pump gas?
My question isn't about how much boost I should run or other tuning questions but I want to find out if the stock box is holding me back and if the cold air intakes really add good power.
Old 01-15-2007, 01:27 PM   #14
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
stock air box is not holding you back, just get a high flowing air filter, thats all you need at your power levels
Old 01-15-2007, 01:55 PM   #15
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
I put down 275whp on a mustang dyno with the stock airbox and a cheap Fram filter.
Eskram is offline   Reply With Quote
Old 01-15-2007, 02:02 PM   #16
cwepruk
Member#: 121757
2005 Subaru Forester
I too put down 270 HP, stock airbox, Kool Blue filter, no snorkel.
EJ255, VF39, STi I/C, protune, header, lower boost than I wanted (pill issues), Mustang dyno. Stage 2 STi typically put down 245 on this dyno. Boost was 15.5 spikeat 3200, then 14-13-12 in 1000 rpm increments or so.
I was curious too if there is any reason to buy an aftermarket turbo inlet.
cwepruk is offline   Reply With Quote
Old 01-15-2007, 03:48 PM   #17
wrxxed
Member#: 20567
04 2014 Forester
Clark Turner tuned my 04 sti and made 305awhp/328awtq on a dynojet,APS 3 inch catless TBE,everything else stock! Look at the Licthfield Type-25 with the stock airbox they made 415 bhp(with many other mods of coarse)so the stock air box is not holding you back!! I do believe at higher hp levels it will eventually not flow enough air but your not there yet. Prove it to yourself go buy a CAI and get retuned by the same tuner on the same dyno @ roughly the same air temps and humidity and see what happens?
Old 01-15-2007, 04:03 PM   #18
WRX_UA
Member#: 116189
2006 WRX Wagon 2.5L
Very black with T518Z...
Well, with stock injectors, they will be more of a limiting factor, not intake.
WRX_UA is offline   Reply With Quote
Old 01-15-2007, 04:24 PM   #19
oversteer
Member#: 14923
2007 Subaru turbo
Excellent idea but since the USDM STi has been out for 3+ years I was hoping that someone already did this test
Old 01-15-2007, 04:48 PM   #20
sjs0433
Member#: 86061
I have a friend that with only colder plugs, and turboback plus a tune made over 300whp on an 05 sti with the stock airbox
sjs0433 is offline   Reply With Quote
Old 01-15-2007, 07:00 PM   #21
CatfaceType-R
Member#: 81102
oh yah i forgot, i am on stock airbox too
Old 01-15-2007, 10:34 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
We did 312whp and 315ft/lbs on our Mustang with 91 octane on the stock intake and TMIC. This was with the Helix RR500 turbo running 21psi tapering to 17psi, the MAF resolution was terrible, the car was flowing about 315grams of air so I don't recommend it (shop car), but we were just pushing the limits of the turbo. Your problem is likely more the stock turbo than the intake.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 01-16-2007, 10:39 PM   #23
RkyMtWy
Member#: 137740
I hit 305whp 345wtq on 91 at 5900 feet. This was on MAC's awd Mustang Dyno with the stock airbox, stock turbo, 3" TBE, Perrin drop in filter, lightened crank, COBB v.1, and the street tuner program. This was on my 2005 STi. Recently I added a turbo inlet and SPT intake and cruised to 314whp 352wtq! If you go that high a tune on the VF39, expect boost creep when it is cold.
RkyMtWy is offline   Reply With Quote
Old 01-16-2007, 11:14 PM   #24
Clark_Kent
Member#: 114299
MAC in Parker? They don't have a Mustang dyno, its a DynoJet AWD 248/224.
Clark_Kent is offline   Reply With Quote
Old 01-17-2007, 12:33 AM   #25
dwaynesti
Member#: 88838
2004 sti
black
i am sure my 20g is pushing over 300whp on most dyno's
stock airbox, stock filter even
dwaynesti is offline   Reply With Quote
Anyone in the Chicago Suburbs want to sell their stock air intake? chomdh Mid West Subaru Owners Club Forum -- MWSOC 5 06-11-2008 09:54 PM
fs de. injen cold air and AEM shortram & stock air intakes blueghost Engine/Power/Exhaust 15 05-11-2007 09:43 AM
WTB: 02/03 WRX stock air intake or trade for Injen cold air intake limpstick VIC Private Classifieds 17 02-16-2007 01:46 AM
Replaced Ganzflow with Stock Air intake, MPG now in the hole DreddRS25 Normally Aspirated Powertrain 8 09-21-2006 06:08 PM
Anyone had problems with cold air intakes? subie4life Normally Aspirated Powertrain 47 08-01-2005 04:00 PM
