Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 01-15-2007, 12:55 PM   #1
NeoteriX
Member#: 20999
2002 PSM WRX Stg 2
knee - Aw - teh - rix
Default Intermittent Oil Pressure Light woes
I just got my car back from the Subaru dealership, and it turns out I had a busted coolant hose.
[disaster history here: http://forums.nasioc.com/forums/show...php?t=1172158]
Everything seems to be running alright, and I made the drive back to Boston without incident. The only cause for concern at the moment though is that the oil pressure light lights up when the car has been sitting for a while, especially in cold weather it seems. After several minutes of idling once the engine temps seem to warm up to normal operating temperatures, the light fades away.
This was clearly not something that occurred prior to the highway disaster. Is this a damaged sensor? Another problem? Cause to call up the dealership and have them make things right?
NeoteriX is offline   Reply With Quote
Old 01-15-2007, 05:35 PM   #2
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
It would not be a bad idea to return the vehicle to the dealer and have it checked. if the engine was overheated, you may have caused some damage to the lower end, and then it may only be a bad electrical connection, or sender unit. Ether way I don't like to ignore a oil pressure warning lamp. It needs to be checked out.
crampfan is offline   Reply With Quote
Old 01-16-2007, 03:34 AM   #3
Hamzor
Member#: 19541
I have the same prob.
After my coolant hose busted ( the one near the alternator, where the oil pressure sensor is located) the oil light will be on very dim during wet weather or in the morning. It usually goes away after five minutes of operation. My oil level is fine. In the current weather, I have not seen it in the last month.
I have been told that to fix the prob you have to pull out the sensor and clean it.
I would not worry about any damage to the car, I read that the oil pressure light has only two modes of operation, fully on or fully off, with it being dim, it has to a short in the system.
Hamzor is offline   Reply With Quote
Old 01-16-2007, 12:45 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The oil pressure warning light is an LED. It only takes a small amount of leakage current to make it light up dimly, since you had a coolant leak there is probably some conductive residue left behind that is providing a ground path for the light. This can probably be fixed by disconnecting the sensor and cleaning the sensor, plug, and surrounding area.
Old 07-19-2008, 03:56 AM   #5
Synx
Member#: 43712
60's B-52H
03 WRX WRB
Bump, good to know Mulder, just had my car towed back to my house because of coolant leak of some kind, not sure where but appears to be coming from the hose that goes into the reservoir tank. Had coolant all over the crank pulley and surrounding areas, followed by a very dim oil pressure lamp. I shut it down right away and had it towed, but this makes me feel a ton better. I am going to drain the oil and coolant when i get back up this morning and see what i find.
Where is the oil pressure sending unit on the EJ205?
Synx is offline   Reply With Quote
Very Dim Oil pressure light scotia Electrical & Lighting 5 12-05-2015 08:50 AM
Oil pressure light esomday Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 06-07-2007 10:31 AM
leaking coolant and oil pressure light lighting up rayman481 Service & Maintenance 2 09-02-2004 07:24 PM
Oil pressure light comes on for a split second WS6toWRX Service & Maintenance 12 02-06-2004 03:47 PM
Oil pressure light on, need opinions Keiho Normally Aspirated Powertrain 12 02-24-2001 08:08 PM
