Old 01-15-2007, 06:29 PM   #1
tspaniol
Member#: 40215
Default P0519 code 2004 Impreza Outback Sport
CEL light on, pulled code at Auto Zone (Actron 9145 OBDII device), says P0519. CEL will come on once every two weeks or less, same code, once light comes on while driving the engine will die (softly) the very next time I come to a stop or push in the clutch pedal (on returning to idle, I assume). It only dies that one time, I can re-start, and drive, and light might stay on for the rest of the day, but won't die again. I've seen the sticky, and the IAC cleaning instructions - but I DON'T have the turbo, just the regular aspirated 2.5. No other drivability or idle issues. Dealer said ok to continue driving as long as CEL is not flashing. Mine is just steady. Any help appreciated.
BTW...why isn't the PCV valve listed anywhere in the maintenance schedule?
tspaniol is offline   Reply With Quote
Old 06-27-2007, 10:06 PM   #2
copytech
Member#: 46020
Bump. My car has the same problem. I cleaned the IAC and went as far as to swap the entire throttle body and solenoid and the problem stays with my car. It only seems to come on when I am going down a long hill with the car in gear clutch out and applying the brake. If I push in the clutch or take the car out of gear there is no check engine light.
Please help
04 TS wagon 149,000 miles
copytech is offline   Reply With Quote
Old 06-28-2007, 09:56 AM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Check the mail relay behind the glove box. Brown 6 pole connector. start the car and tap on the relay and see if the car acts up.
Old 07-08-2007, 09:43 AM   #4
copytech
Member#: 46020
Didn't change anything,
Old 10-19-2007, 02:20 PM   #5
tspaniol
Member#: 40215
Yep - my situation exactly. Just happened today again, while going downhill. I haven't had it all summer long, but now it is back.
Old 10-19-2007, 02:21 PM   #6
tspaniol
Member#: 40215
"Mail" relay? Why would it be called that?
Old 10-19-2007, 02:41 PM   #7
tspaniol
Member#: 40215
Now I'm beginning to wonder if this is related to wet driving conditions - and a short somewhere.....besides IAC, TPS, etc.
Old 11-20-2007, 12:45 PM   #8
wrx-boy
Member#: 43662
2005 STi
CGM
Bringin' this one back!!
Same issues here with my wifes 03 Outback Sport. I've replaced the Idle Air Control Valve (Still Get the cell) so went back to the old one and cleaned it up with brake clean and it seems to be working. I've heard that it could be an issue with a vaccuum leak but how you find that I have no idea.
wrx-boy is offline   Reply With Quote
Old 11-22-2007, 12:28 AM   #9
fog
Member#: 35911
2002 WRX Gutted
More than likely it is a very small vacuum leak. Have the engine smoke tested. It is an annoying code that is a pain in the neck to find the solution for sometimes. Basiclly the failsafe kicks in and temporarily kills the fuel to cylinder 1 and 2. Also check that there isnt any slop in the accelerator cable. And of course the obvious is debris in the bypass circuit.
Rich
fog is offline   Reply With Quote
Old 01-23-2008, 01:31 PM   #10
orndog
Member#: 34670
2013 No gears!
Saltine American
Bringing it back. I got this one this morning. I downshifted to 4th at about 50mph to coast down to a stoplight and the light came on. Car continued to run normally all the way to work. Guess I'll just reset the light and see if it comes back.
orndog is offline   Reply With Quote
Old 01-23-2008, 07:13 PM   #11
orndog
Member#: 34670
2013 No gears!
Saltine American
Reset with the tool at work, drove home, no light. *fingers crossed*
Old 01-26-2008, 05:38 PM   #12
teeots
Member#: 140731
Me too! I cleaned my idle air control valve three times and can't fix the problem.
Mine cold starts and idles around 1750 then when it kicks down to the "slow" idle it ends up around 1300-1400. It throws the code p0519 when it kicks down. Then if you let it idle long enough, it creeps up to near 2k. When it kicks down it becomes rough almost feeling like a bad misfire-very chopppy if you press the accelerator. Car is pretty much undriveable. The code reader always shows the same code twice-not sure why? I wonder if its worth replacing the iacv- the dealership said they have only replaced one ever, but do clean them sometimes.
Oh yeah, mine is an 03 wrx with a 2.5 block and custom tune.
teeots is offline   Reply With Quote
Old 12-17-2008, 02:24 PM   #13
KartingFool
Member#: 172423
04 Impreza TS
Default dirty air filter?
over the course of 90k miles, have had the CEL come on many times, everytime it was the 519 - idle control....
in each case, the air filter had nearly 10k, replacing it made the CEL go away
i now replace the air filter every 5k as part of my regular tune up - havent seen a CEL since
KartingFool is offline   Reply With Quote
Old 12-17-2008, 03:20 PM   #14
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
a faulty neutral switch seems to be the common cause of these IAC codes when no other failure can be found. I know the manual mentions nothing about it in reference to this code.
Old 12-27-2008, 09:04 PM   #15
PsiAddiction
Member#: 146714
2007 STI
Dark Gray Metallic
they dont mention it because only automatics have the switch..i believe.. im going through this same problem also.. got a new transmission and it sat for a bit. went to get it....drove it and threw the P0519 code mine acually showed it twice also. one said pending.. but i heard this was because of a bad IAC, so like stated i tried to clean it and been driving it for 2 days and still does the same thing. idles at 2k then the cel comes on then it drops to 1.4k-1.5k but sometimes goes back to 2k. so thinking about just buying a new IAC if i need to because cleaning didnt work. please let me know. i also had it idle, popped the hood and unpluged the sensor and nothing happening when i unplugged it or put it back on!!
Evan
PsiAddiction is offline   Reply With Quote
Old 12-29-2008, 09:40 PM   #16
mreece53
Member#: 198677
Default P0519 Cel
Had My 04 Impreza Outback To Garage Today........Mechanic Said Code Was Likely Neutral Switch. (it Is Manual Trans) Is This A Reasonable Diagnosis?
mreece53 is offline   Reply With Quote
Old 12-29-2008, 11:05 PM   #17
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Manual trans cars have a neutral switch its on the left rear of the transmission next to the back up light switch.
The diag for the code never mentions a neautral switch as possible problem but it does seam to fix these types of codes alot.
Old 07-30-2009, 10:17 AM   #18
eXotek
Member#: 76340
I'm faced with this exact issue. I used to have high idle in hot and high traffic conditions, sometimes the idle would go up past 3000 RPM and sometimes when i came to a stop the car would bog down. I changed the IAC to another used IAC that i cleaned (which I'm pretty sure worked fine in the previous car, but it has been sitting for a year and a half unused). The high idle issue appears to be gone, but the car will still bog down once or twice after coasting and comming to a stop. I will keep on the throttle during that time and the issue goes away and I can drive fine. I do get the P0519 CEL just before it bogs down. What are the chances of 2 bad IACs lol (could be high i guess heh) Anyone have any more stories on how else they have resolved their p0519 issue (besides changing/cleaning IAC)?
eXotek is offline   Reply With Quote
Old 10-13-2014, 11:04 AM   #19
scoobyblu3
Member#: 403024
Default 2004 Outback Sport downhill CEL P0519
Just wanted to bump and confirm the comments above from my own experience.
2004 Outback Sport manual trans., CEL would come on when coasting on the engine downhill, and once the CEL came on it died the next time i put in the clutch. The car seemed to run perfectly otherwise. The car also often bucked at slow speeds, but it had be doing that the whole time I've had it, so I didn't realize there was a problem. This went on for years but I never fixed it because the car seemed to run fine aside from the occasional hill problem.
Long story short, it was the Neutral Switch. Apparently it was telling the car it was in neutral when it actually was in gear. So when you're coasting it thinks the idle should be lower than it is and throws the CEL for a throttle issue. I don't know exactly how the neutral switch effects the throttle in traffic, but the car used to buck when you took your foot off the gas at lower speeds. The car is driving much better now- at 135k, it's like driving a new car!
scoobyblu3 is offline   Reply With Quote
Old 04-23-2016, 04:37 PM   #20
Chez rolez
Member#: 445391
Default P0519
Bump. I've been lurking these post for a while, good help.
I have the p0519 and p0030 codes persistently on my manual '03 legacy.
I replaced the neutral safety switch, which was in fact broken (full disclosure, I definitely may have done this during the removal).
I have also removed and thouroughly cleaned the IACV, and the housing in which it resides. No luck.
I'm probably going to replace that valve, they go relatively cheap on eBay, but I'm not convinced that's the issue. Already overdue on the emissions inspection, anybody have any other recommendations?
EDIT: also replaced the air filter.
Chez rolez is offline   Reply With Quote
2004 Impreza Outback Sport [email protected] Private Vehicle 'For Sale' Classifieds 0 03-22-2007 11:03 AM
In search of new 2004 Impreza Outback Sport Catsmeow General Community 4 01-10-2005 02:57 PM
Head unit from a 2004 impreza outback sport velodanny Private 'For Sale' Classifieds 0 01-08-2005 04:22 PM
Body Kits for 2004 impreza outback sport??? velodanny Interior & Exterior Modification 3 01-08-2005 12:33 PM
Sunroof for 2004 impreza outback sport pastormikeis Interior & Exterior Modification 1 07-29-2004 07:11 PM
