Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 01-15-2007, 06:45 PM   #1
tappets
Member#: 137771
Default 92 legacy - couple of questions
Hi all,
i'm new to the subaru world. i have inherited a 92 legacy awd 2.5L auto wagon. auto transmission is completely ruined. found drive shaft to replace former pretzel-shaped driveshaft. everything else on car operates just great and the engine runs like a top.
i would like to replace the transmission and return the car to daily driver status.
what i.d. numbers should i look for?
where would the numbers/number plates be located on the transmission?
if you need more details, let me know. hopefully someone can help me with these details, so i don't waste a lot of time locating the wrong parts.
THANKS!
-Gary
tappets is offline   Reply With Quote
Old 01-15-2007, 07:11 PM   #2
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
Are you sure it's a 2.5L? That would not be a stock configuration on any pre-96 car.
Wiscon_Mark is offline   Reply With Quote
Old 01-16-2007, 11:17 AM   #3
tappets
Member#: 137771
2.4L sound better? my mistake.
Old 01-16-2007, 11:52 AM   #4
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
No...Subaru never had a 2.4L
A 2.2L was stock on all Legacys of that model year.
Old 01-16-2007, 02:56 PM   #5
tappets
Member#: 137771
cool, i'm sure i'll learn more about them as i work on it, so please forgive my lack of knowledge.
any i.d. numbers on the trans case or wherever that i can use to find a proper replacement - as in, what year cars/wagons/models may have used the same transmissions?
thanks
Old 01-16-2007, 04:29 PM   #6
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
You'll find this'll be the answer to many of your questions: Subarus are like legos...pretty much everything works between models.
that being said, any EJ engine and any EJ transmission will be interchangable. Anything from any Impreza, Legacy, Forester, etc.
Just make sure you match up gear ratios to the rear differential.
Old 01-22-2007, 05:45 PM   #7
tappets
Member#: 137771
Default this should do it.
EJ22 from a 90 legacy L 2.2 located, trying to get details. this should be ok though, from what you've mentioned. thanks for your input!
New to the World of Boost: Couple of Questions! FenKa856 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-15-2009 02:25 PM
92 Legacy EJ22T downpipe question 00boostedRS Pre-2002 Factory Turbo Powertrain 19 01-19-2009 04:37 PM
92 Legacy Climate control question? Dealer Xing Legacy Forum 3 11-27-2004 12:27 AM
('93-'01) couple of questions newgrandpa Impreza Forum 0 06-06-2001 06:56 AM
a couple of questions skeisenb Legacy Forum 7 03-20-2001 07:37 PM
