Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-15-2007, 09:13 PM   #1
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Default Tell me about my timing PLZ.
My DA(A,B,C) tables are set to the same value (8). I also re-did my primary ignition for these targets.
Timing below 2000 RPM STOCK
18 at 4000 RPM
22 at 5000
24 at 6000
29 at 6800
Thanks
Marcos
STISTL is offline   Reply With Quote
Old 01-15-2007, 09:52 PM   #2
Rexfan
Member#: 50993
02 WRX Wagon
2.5/Blouch Dom 3/Meth/6sp
I wish I could help you, but it looks like you are "knock knock knocking on heavens door"
I probably wrong.......I'm sure there's someone who can help you. Good luck.
Rexfan is offline   Reply With Quote
Old 01-15-2007, 10:09 PM   #3
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Can you tell me were do you see knocking? My knock lerning table is clean all Zeros. BTW I'm a noob just trying to learn.
Thanks
Marcos
Old 01-16-2007, 02:05 AM   #4
Gethin
Member#: 2998
KC looks good can u explain where you see knock?
Gethin is offline   Reply With Quote
Old 01-16-2007, 09:37 AM   #5
Zumble
Member#: 34860
2005 Forester CGM
That log doesn't show knock..
Zumble is offline   Reply With Quote
Old 01-16-2007, 10:40 AM   #6
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
no knock, but no boost either :P
23psi midrange, 16.5 at redline FTW
boost onset sucks too, catted downpipe?
overdose is offline   Reply With Quote
Old 01-16-2007, 10:41 AM   #7
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
LOL and that guy(Rexfan) has a Green with Alky. He obviously didn't tune his own car.
akira02rex is offline   Reply With Quote
Old 01-16-2007, 11:08 AM   #8
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Timing looks okay-
What does your AVCS look like?
Mike
crazymikie is offline   Reply With Quote
Old 01-16-2007, 05:40 PM   #9
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
I still have the stock catback(catless) I think that's why my boost drops so fast at high RPM.
Thanks
Marcos
Old 01-16-2007, 05:41 PM   #10
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Originally Posted by crazymikie View Post
Timing looks okay-
Mike
AVCS is completely stock, I still need to learn a little bit more about it before I make any modifications.
Thanks
Marcos
Old 01-16-2007, 06:32 PM   #11
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I don't see any knock in that map, but you also didn't post a copy of your KC table so I don't really know.
Old 01-16-2007, 06:44 PM   #12
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
DA table is set to 8 exept for the las 3 rows I think 6400 rpm and higher that are set to 9. Knock Correction table is full with zeros.
Thanks
Marcos
Old 01-16-2007, 11:02 PM   #13
crazymikie
Member#: 56321
Green
Your mapping looks safe- you should work on the timing during spoolup, though. Ideally, you would want timing to drop during spoolup and once you hit peak engine load, you would want timing to steadily increase until redline. It looks like you could smooth things out a bit during the period right before you hit peak engine load.
Mike
Old 01-16-2007, 11:59 PM   #14
STISTL
Member#: 69659
07 BMW 335
12.6 @ 111.1
Mike
Hey Mike thanks for the input. When you say smooth things out do you mean to have less repetition of the same value in the log.
Thanks
Marcos
OTters: Tell Me About Your CornHole. Your Cornhole... Tell Me About It. Asinine Off-Topic 60 09-10-2008 01:23 PM
Tell me about my spark plugs... Spoolin415 Service & Maintenance 6 04-15-2008 10:07 PM
Tell me about my spark plugs... Spoolin415 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-13-2008 12:07 AM
tell me about a time when it would feel real good to burn a bridge, but it turned out friedbbq Off-Topic 4 10-14-2005 04:07 PM
Alot of Slips...tell me about my car. gusto Proven Power Bragging 21 06-27-2005 07:38 AM
