Old 01-15-2007, 11:57 PM   #1
hampster
Member#: 15766
torq steer=something
cattlemen do after work.
Default Clutch Shudder--Worth Fixing?
Well, my WRX still has the infamous clutch shudder. I'm nearing the end of my warranty, so I figured I'd check with the folks here to see if you think it's worth having SOA fix?
I guess the decision is between:
1) Dealing with the clutch shudder....or
2) having dealership try to fix it...and dealing with all the stuff they will likely screw up in the process of fixing the clutch.
Of course, if the dealership fixes don't last long or if the clutch shudder can cause drivetrain damage, then those would be factors to consider...
hampster is offline   Reply With Quote
Old 01-16-2007, 12:01 AM   #2
vale2489
Member#: 107812
91' 240sx sr20det
02' wrx will be missed
I had mine fixed no questions asked, and they replace the whole clutch/flywheel assembly with an upgraded unit...haven't had a problem since. Might as well get it taken care of while it's free
vale2489 is offline   Reply With Quote
Old 01-16-2007, 12:11 AM   #3
SwisSlesS
Member#: 122445
2006 WRX Wagon
Steel Grey Metallic
If you can get it done for free, definitely do it. I'm guessing you'll have a tough time getting it covered though.
SwisSlesS is offline   Reply With Quote
Old 01-16-2007, 10:37 AM   #4
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
if you can get it done under warranty do it,
if not I wouldn't worry too much about it.
clutch shuddering for the past 138,000 miles
dm
dwmoss_68 is offline   Reply With Quote
Old 01-16-2007, 11:16 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
learn to drive around it. unless it is really bad, it should only be a combination of temperature, rpm, and load that cause it. changing any one of those (different rpm or speed of engagement to change load) should keep it from shuddering.
Old 01-16-2007, 02:31 PM   #6
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
this is what i do
dm
Old 01-16-2007, 02:35 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What warranty are you referring to? The shudder was only repaired for free under the 3/36 bumper-to-bumper which has long passed, it is not covered by the powertrain warranty.
Old 01-16-2007, 03:00 PM   #8
hampster
Member#: 15766
Dammit, mine didn't really have the shudder problem until it was 4 years old. I figured clutch = drivetrain so it would still be covered...
Old 01-16-2007, 03:21 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Nope, the shudder fix was a TSB and those are only done under the 3/36.
Old 01-17-2007, 01:49 AM   #10
Black07STI
Member#: 136814
07 Impreza WRX STI
What exactly is clutch shudder?
Black07STI is offline   Reply With Quote
Old 01-17-2007, 08:53 AM   #11
rkramer
Member#: 118209
2015 WRX Limitec
earlier wrx's had a lighter flywheel, and combined with the clutch, would shudder when you let off the clutch from a stop. (entire car would shake from the clutch more or less bouncing)
as i mentioned above, only at certain temps, rpms, and loads. The fix was a heavier flywheel IIRC.
Old 01-17-2007, 09:21 AM   #12
z&cobb
Member#: 12344
2002 2JC
blue
When I had the clutch replaced I made sure I got the "non" fixed parts. I didn't want it dumbed down, but that was an option. Maybe once or twice a month I have to finese the clutch from a stop, to keep this little bit modified wrx from jumping all over the road.
z&cobb is offline   Reply With Quote
Old 01-17-2007, 10:10 AM   #13
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
3/36 that was sooooo long ago!!
Clutch shudder and fixed? ghostfoot7 Vancouver Impreza Club Forum -- VIC 10 05-18-2005 05:54 PM
Should my clutch shudder be fixed again? Alldidasmc Warranty Issues & SOA Problems 0 10-19-2004 11:14 AM
Has anyone had a clutch shudder problem fixed in the north bay? thrashvr6 Bay Area Impreza Club Forum -- BAIC 3 04-23-2004 10:38 AM
('93-'01) Anyone actually had the clutch shudder fixed? JasonRan Impreza Forum 43 09-20-2001 11:39 PM
