Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 01-16-2007, 03:13 AM   #1
Inder
Member#: 137838
2000 Legacy GT Sedan
Timberline Green
Default 2000 Legacy GT EJ25 Phase II SOHC ADD TURBO?
Please go to the following like, rather then have the same sort of thread on multiple forums, I am keeping it all here:
http://spda-online.ca/modules/newbb/...d=3186&forum=9
Last edited by Inder; 03-04-2008 at 12:42 PM. Reason: Must have been falling asleep when I wrote this post. I have to laugh at some of these typos, lol.
Inder is offline   Reply With Quote
Old 01-16-2007, 04:00 AM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Do a search. also, try the forced induction section. Plenty of RS-T's with phaseII motors running around.
rougeben83 is offline   Reply With Quote
Old 01-16-2007, 09:24 AM   #3
that one legacy
Member#: 103665
if i recall correctly, the bottom end of the phase II blocks can't handle more than 9-10 lbs of boost for long periods of time, but even those low numbers can really make the phase II come alive. i just hope you don't have the crappy 4EAT like me, cause i've been hearing that those don't like any kind of boost.
that might all be heresay though, cause i have yet to try something like this on my own car. like rougeben83 said, try poking around the F/I forums. anything that works for the Phase II 2.5 RS should work for your car with little difficulty.
that one legacy is offline   Reply With Quote
Old 01-16-2007, 10:19 AM   #4
ten80
Member#: 53625
00 EJ205 LGT LTD
Actually, the subaru 4eat is surprisingly stout and can usually hold more power than the 5mt. Torque converters are very efficient at dissipating shock and stress. Most stick to 6 PSI +/- to be on the safe side. 6 PSI on your ~10:1 compression engine will give right around 230hp (180-190whp) which is should be a HUGE upgrade in power. Before you consider turbo'ing your motor, be certain that your head gasket is still ok. You're car is of the age where a blown HG would't be surprising- my 00 leg blew it's HG around 125k miles. There are several ways of checking for this, all easily found with a quick search in the N/A forum.
Basically, it is possible to add a turbo. Expect to spend in the neighborhood of $1500-3000 for a used kit and plan on a "backup motor fund" in case things go wrong, which isn't uncommon. I'd say you should consider a WRX motor swap, but as I'm finding out, it's not an easy enveavor in a BE.
ten80 is offline   Reply With Quote
Old 01-16-2007, 11:03 AM   #5
rougeben83
Member#: 115154
2005 Outback XT
White on grey
6psi is roughly more around 250-260hp, but that's by going by the numbers the AVO kit produces. 230hp is more like if you run a poorly tuned EM, or the cheapo RRFR/knock sensor setup; it will work, but not very well.
I think people underestimate how hard engine swaps are for any subaru; the suggestion gets thrown around on forums quite often because...well typing it is easier than actually doing it . Anyway, I think it will be worth it once you finish it (either way, as I'm going the kit route), but you just have to know what you're getting into, be prepared for problems, and not get frustrated to the point of quitting all together in the process.
Old 01-16-2007, 02:42 PM   #6
legacydreamz
Member#: 92423
2007 Honda CRV
and dolphins and s**t
OK. get a dyno sheet to prove that.
250-260hp for 6psi???
RIGHT
legacydreamz is offline   Reply With Quote
Old 01-16-2007, 02:45 PM   #7
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
RIGHT
Considering the CR, if you can safely run that PSI, you should be able to make some good power. And he's not talking whp.
Wiscon_Mark is offline   Reply With Quote
Old 01-16-2007, 02:56 PM   #8
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
RIGHT
http://www.rallitek.com/avocotukit.html
And like he said, he was just going by AVO's #'s.
legacy99black is offline   Reply With Quote
Old 01-16-2007, 03:19 PM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Also, per JoeT, who has probably done more with boosting the NA in a Legacy than anyone here.
http://spda-online.ca/modules/newbb/...forumpost20511
A high compression ratio may be bad for adding tons of boost, but while it's there it does have a sort of multiplier effect to the boost that you are already shoving into the engine. It's just a matter of whether you can stay away from the Boost Addiction
Old 01-16-2007, 11:46 PM   #10
Inder
Member#: 137838
Timberline Green
Default Thank you for the fast replies.
Moved to SPDA forums.
Old 01-17-2007, 12:05 AM   #11
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
XIce tires rule!
<---rocks a set for winter
Old 01-19-2007, 11:11 PM   #12
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Read the Zen Series here -> http://spda-online.ca/modules/newbb/...um.php?forum=9
Lots of information available.
JoeT is offline   Reply With Quote
Old 03-10-2008, 11:53 PM   #13
Inder
Member#: 137838
Timberline Green
JoeT and the Zen series is great material to read for anyone with the same questions I have about turbo'ing the NA EJ25 SOHC engines.
Phase I DOHC/MAF and Phase II SOHC/MAP pin-out diagrams? Patrick Olsen Normally Aspirated Powertrain 7 02-09-2006 05:23 PM
Question about WRX Fuel Rails on EJ25 Phase II SOHC engine JoeT Normally Aspirated with bolt-on Forced Induction Powertrain 26 02-03-2006 09:51 PM
MY00 EJ25 Motor Phase II SOHC 76k miles/synthetic oil erice1984 Private 'For Sale' Classifieds 4 07-25-2005 04:32 PM
Will a Phase I DOHC run using a Phase II SOHC ECU? Patrick Olsen Normally Aspirated Powertrain 12 10-11-2004 01:27 PM
Parting out Phase II SOHC EJ25 engine pitcrew Private 'For Sale' Classifieds 26 06-03-2004 01:55 AM
