Old 01-16-2007, 04:18 AM   #1
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Default BE front sway bar interchangeability
Hey guys,
Anyone know if the front swaybar on the BE's are interchangeable with other subbies? (namely 2.5RS's)? I know the endlinks work, but not so sure about the swaybar itself...
rougeben83 is offline   Reply With Quote
Old 01-16-2007, 10:40 AM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Since the suspension and tracking are the same...I would assume yes.
I don't know if anyone has really tried it though.
Wiscon_Mark is offline   Reply With Quote
Old 01-16-2007, 11:07 AM   #3
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Hmm, then anyone got a pictures of their BE fsb?
Old 01-16-2007, 12:45 PM   #4
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I'm not sure about a BE, but if it helps, I'm using a BD front swaybar on a BC, which would have the same fitment as a 2.5RS. If BD and BE swaybars are compatible, then it will probably work. You'd need new front bushings for sure though. W0404-[mm] is the Whiteline part number.
jamal is offline   Reply With Quote
Is an 04 USDM STI front sway bar identical to an 04 WRX sedan front sway bar? legacy2003 Brakes, Steering & Suspension 1 10-01-2009 05:25 PM
ADDCO Front Sway Bar for BE Legacy lgt2000 Legacy Forum 12 07-06-2007 11:01 AM
STi and WRX front sway bars interchangable? scoobie1 Brakes, Steering & Suspension 1 10-03-2005 10:45 PM
Sway bar question, will a cusco front sway bar from a sedan fit on a wagon slprwrx Brakes, Steering & Suspension 5 05-10-2003 09:41 AM
Does 02 wgn and sedan sway bar interchange? Marty S Brakes, Steering & Suspension 6 10-21-2001 03:16 PM
