Old 11-26-2001, 12:35 PM   #1
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Default Is it possible to perform coolant flush without engine?
Hi all,
I am in the process of swapping out my DOHC engine and replacing it with a SOHC engine from a 2001 legacy GT. The original engine had a blown headgasket which leaked oil into the coolant reservoir (and I'm guessing the radiator and hoses as well), leaving minute oil deposits. I would like to clean out the coolant system before installation of the new engine.
Is it possible to perform a coolant flush (or clean out the oil deposits) from the radiator and coolant reservoir without the engine installed?
Thanks,
Jason
2.5GT is offline   Reply With Quote
Old 11-27-2001, 12:07 PM   #2
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
Sure, you can run a flush through the radiator without the engine. I'd use a little cleaner/degreaser on the first fill (you'll need to plug the main radiator hose outlets) and use hot water. Then a couple of flushes with clean water and all the oil traces will be gone. The overfill tank and hose is pretty easy too - but doing the heater core and hoses will be a little more interesting - I'd suggest using the garden hose into one side and the flow through it should clean it out.
Alan is offline   Reply With Quote
Old 11-27-2001, 03:14 PM   #3
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
Thanks Alan,
I was starting to worry that nobody would be able to answer my question.
Jason
Is it possible to replace WG actuator without removing turbo? gopsu Newbies & FAQs 12 09-05-2009 12:43 AM
Is it OK to drive a car without coolant? Gerkins31 Off-Topic 17 02-25-2006 01:43 PM
is it possible to eat a muffin without getting crumbs everywhere? catass Off-Topic 17 07-04-2005 01:58 PM
Is it possible to finish a Chalupa without stuff falling out the other side? perret318 Off-Topic 18 11-12-2004 02:59 PM
Installed Vishnu up-pipe: Is it possible to reach extra bung without taking out upipe nicktckhoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-14-2002 01:06 AM
