Old 11-26-2001, 01:54 PM   #1
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Silverthorne Metallic
Unhappy Engine mounts squeak?
As you can see I have a my01 RS. After a road trip over the Thanksgiving holiday, my engine has developed a squeak. The squeak happens whenever the throttle is blipped or whenever I go over bumps. It will also happen when the engine is turned off and you bounce the car. I crawled under my car and pushed on my headers and on my tranny and was able to reproduce the squeak.
Is it possible for the engine mounts to squeak? And if so, is it bad? Do you think the dealer would replace them under warranty? Or is there a way to 'lube' the current ones?
Or perhaps it isn't the engine mounts at all? Any suggestions?
-Dean
RigdenZW is offline   Reply With Quote
Old 11-26-2001, 01:58 PM   #2
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Also, if I have to replace them out of my pocket... I'll probably see if I can have COBB put in hardened mounts. Anybody have them do this and would know about what the labor cost would be?
-Dean
Old 11-26-2001, 03:27 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
on the passenger side of the trans case there is a rubber coated wiring harness clamp....i had one stuck out rubbing against the body and sqeaking like a MOFO...i have a MY01 as well. CHeck that out.
jeremy
Old 11-26-2001, 04:06 PM   #4
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
Thanks, Jeremy... I will definately check that out when I get home today. In your case.. what was the solution?
-Dean
Old 11-26-2001, 04:07 PM   #5
AC Lerok
Member#: 7918
2007 FSXT
Obsidian Black Pearl
this describes exactly the noise i have, sometimes i hear it when pulling off in first, too. it doesn't seem to be drivetrain or suspension related, i get the noise independent of what gear i'm in. however, over bumps, it seems like whatever's causing the noise is "floating" . . . it keeps moving and squeaking even after the rest of the car has become stable.
i hear it coming from up above the tranny case, i think. will investigate.
AC Lerok is offline   Reply With Quote
Old 11-26-2001, 04:39 PM   #6
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Mice I say, Mice.
They live in yout intake snorkel and drag the dog food in there... ever wonder what those rattles were?
Squeak, rattle rattle......
(actually happened to my parents Lexus.....)
Midwayman is offline   Reply With Quote
Old 11-27-2001, 03:42 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
i jsut bent in back over the wire like it should have been in the first place.
Jeremy
we get squirrels chewing thru wires all the time.
edit: added the squirrel part
Old 02-14-2002, 02:45 PM   #8
RigdenZW
Member#: 4531
2001 2.5 RS Sedan
** UPDATE **
It's been one day since I've had my car back from the dealership and it is no longer squeaking.
Apparantly, there was a plate assembly above my transmission that was loose and rubbing. They tightened it and so far, it seems to have fixed it.
Just wanted to let you guys know the fix to MY problem so if anyone had similar issues you could check it.
- Dean
STi Heavy Duty engine mounts vs.Stock WRX engine mounts Aspenbullet Transmission (AT/MT) & Driveline 16 04-30-2008 09:13 AM
wtb: new sti stock engine mount / or group-n engine mount (CA) ttake Private 'Wanted' Classifieds 1 11-09-2007 12:07 PM
SMC Alcohol Kit, Cusco Engine Mount & Group N Engine Transmission Pitch Stop Mounts Sti_ck_IT Engine/Power/Exhaust 27 07-23-2007 02:11 PM
FS:STi engine mount,tranny mounts pitchstop mount CHEAP schuey_1 Drivetrain 8 09-15-2006 04:20 PM
Squeaking/creaking engine mount. Please help! fpa1974 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2002 08:42 PM
