Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 01-16-2007, 03:01 PM   #1
sc00ter
Member#: 117767
2015 WRX Sedan (6MT)
CWP
Default idling under 500 RPM's
I had my front 02 sensor replaced under warranty last week. Since then my car has been idling under 500 RPM's constantly. I reset the ECU 2 times (unplugged neg. battery terminal for 30 minutes and held the brake for about 15 seconds) to no avail.
Anyone experienced a similar problem? How bad is this for my car?
Any help will be great. Thanks.
sc00ter is online now   Reply With Quote
Old 01-16-2007, 03:54 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
it isn't a problem, as long as it isn't surging and is stable. (even then it really isn't a problem) give it more time and don't reset the ecu, it might take 2 weeks of normal driving to find a good idle point by itself.
Old 01-16-2007, 05:08 PM   #3
sc00ter
Member#: 117767
CWP
Noted. Thank you.
Old 01-16-2007, 05:24 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Are you shure it's under 500...it's probly under 750 as that the first line down from 1,000, and there is another line that is the 500 line just above the 0.
wrxdrvr is offline   Reply With Quote
Old 01-16-2007, 06:09 PM   #5
sc00ter
Member#: 117767
CWP
nope, its below the 500 (the line barely above 0)
Old 01-16-2007, 06:12 PM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Are you verifying the 500 rpms with a datalogger, or with the analog tachometer that is in your vehicle?
-paK +1
Pakin is offline   Reply With Quote
Old 01-16-2007, 06:25 PM   #7
sc00ter
Member#: 117767
CWP
Just looking at the Tachometer in the car. But also it feels like it wants to stall when idling.
Old 01-16-2007, 06:58 PM   #8
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Try getting ahold of a datalogger to see what the ECU is seeing for your RPMs
The tachometer is not always accurate. Mine after a good warmup says 400ish RPMs, but using datalogger it fluctuates within 700rpms.
If it is of any sustained concern, you can notify the dealer of this issue after you taken it to them for some previous work.
-paK +2
Idle at 500 RPM? The Rusty Gear Normally Aspirated Powertrain 30 03-19-2007 05:41 PM
FS: Nokian WR's, 225/45R 17, Under 500 Miles NlsBold Tri-State Area Private Classifieds 2 01-14-2006 10:52 AM
FS: Nokian WR's, 225/45R 17, Under 500 Miles NlsBold Tri-State Area Forum 0 12-17-2005 09:58 AM
will not idle under 1400rpm while rolling bugite Normally Aspirated Powertrain 8 10-22-2005 12:23 AM
ProTorque stalls @ 4,500 RPM's WagonRX Transmission (AT/MT) & Driveline 13 01-04-2003 09:00 PM
