#1 |
Member#: 70395
I know one of the main differences is Eginuity is free and ECUedit is $120 for thenwhole package.But as far as functionality which one has more promise?Does ECUedit offer more tables/maps?Is one more user friendly than the other?I do have a LC-1 and noticed the ECUedit logger allows use of this wideband.
#2 | |
Member#: 115771
NWIC
Vehicle:2006 WRX WAGON OS Stage 1 |
#3 |
Member#: 44771
Since I'm a dev on the Enginuity project take what I have with a grain of salt, or a brick of salt....
Enginuity is actuallly a communty of people working towards a tuning suite. ECUedit is one guy. Eninguity provides logging, wideband LC-1 integration, map editing, map smoothing, 3D eye candy, etc. Basically everything that ECUedit provides. Enginuity runs on Windows, Linux and Mac. Enginuity is the source for all mappings into ROMS, we support it best. ECUedit steals our mapping work. Enginuity is working on realtime mapping and flashing currently (I have no idea if ECUedit is, though I'm sure they'll steal our realtime maps at some point) Enginuity is Open Source, and thus will always be free. No bait and switch shareware crap. We speak the english. Ok that was mean. But you'll get some good answers to questions on our forums. We're actually a community. -E- |
#4 |
Member#: 118209
Vehicle:2002 WRX Sedan |
#5 | |
Member#: 44771
ETA? Maybe 6mo for 16bit ECU's, though I tend to sandbag quite a bit. I hope merchgod can chime in. He's the hero on all this. ![]() |
#6 | |
Member#: 70395
#7 |
Member#: 103136
We've decided to scrap the original method for real-time tuning and go after something more ambitious. Instead of a having a fixed set of real-time maps that are already determined for you, we will allow the user to select which real-time tables they wish to tune (from a pool of about 19 tables). The number allowed will vary depending on the size of the tables you select (since unused ram is limited on the 16bit ecus). In addition, map switching capability will be integrated allowing you to switch between your selected real-time maps in ram to their corresponding tables in the rom on-the-fly (our current method is car is stationary, rpm>2500 and then defogger on to switch maps). We call the real-time tuning RamTune. We're in the process of testing launch control and per gear boost/wg compensation as well and the results are good - these will also be real-time maps. This week I'll be testing the new RamTune code on my own car and if everything goes smoothly then development will shift to the java guys. It would be impossible to guess a timeframe as there are other features being worked on, but I would guess 2-3 months with all new features packaged together and available for the 16bit ecus (02-05 wrx). As far as Ecuedit, it is a good program and you should use both and decide for yourself - after all it is your "baby" that you are tuning. As mentioned, Ecuedit is shareware, so some features will be disabled in the free version or a timed delay will be present. The advantage of Enginuity besides that it is free and has better forum support is that the ecu definitions and rom features are being actively developed. The advantage of Ecuedit is that is currently has some features that Enginuity does not currently have, such as road dyno, in-program definition editor, and rom comparison. Although, you are likely to see these features and more as Enginuity is developed. |
#8 |
Member#: 122312
Vehicle:2004 STI Blue |
Are there any applications for subi's that will display real time gauges on the laptop screen? Or will either of these apps be doing that in the future?
#9 |
Member#: 44762
Vehicle:2013 BRZ WRB |
LC-1 integration in Enginuity isn't ready just yet, but Joe from Innovate is working on it and he is a very bright guy that knows it better than any of us. It will hopefully be ready for the 0.5.0 release, probably some time in February.
There is a realtime dash program being worked on on openecu.org called JDash. Do a search there and you should be able to find it. EvoScan apparantly is also working on adding SSM support. It'll be added to Enginuity eventually but it's really pretty low priority as it's more eye candy than useful. EcuEdit does have some features Enginuity does not, and will likely have any new feature Enginuity does eventually. The real advantages to Enginuity are portability, support and cost. Plus the GUI, if it suits your taste more than EcuEdit. Edit: You can also use the OpenPort with Innovate's new LogWorks plugin that'll give you realtime gauges, though I don't think you can "skin" them or make them much prettier than they already are. This is what I'm using for wideband logging until its fully integrated in Enginuity. |
#10 |
Member#: 25777
Is LM-1 integration planned for enginuity? or just LC-1?
I use both enginuity and ecuedit. The only feature I use on ecuedit is the 3D graphing. I find it's easier to smooth things out with the graphical representation ecuedit has vs the one that enginuity has. Otherwise it's enginuity for everything. |
#11 |
Member#: 44762
All of Innovate's MTS hardware will be supported at once. From there we can begin adding support for other widebands as we are able to get ahold of them, or maybe we can get the support from the manufacturer's the way Innovate has (but I'm not counting on that).
#12 |
Member#: 85768
RMIC
Vehicle:06 TR OBP |
Now that i know enginuity runs on Mac I am sold! Is there anywhere I can download a basemap to get me started? 06TR InvidaDp, 3" catback.
#13 | |
Member#: 99289
#14 |
Member#: 99289
This may not be the appropriate spot, but would there be a way to use an "unused" input (say rear, 02 sensor) to change the fuel injector information? I ask this, because I would love to integrate a ethanol mix sensor that would automatically change the fueling to match the injected mix, so I could run E85, or straight fuel, or anything in between, without teaching my wife how to change tables.
#15 |
Member#: 44762
It would be possible, but we haven't done anything like that yet. Also, I don't believe there are any unused pins on the ECU, so you'd have to lose something. TGV sensors or rear o2 would be my first bet. Eventually we should be able to use pins for controlling water injection, nitrous or whatever else you want.
#16 | |
Member#: 112790
Regards |
#17 |
Member#: 63292
South East
Vehicle:2000 Subaru 2.5RS 2002 WRX powered |
im pretty sure there is atleast one unused pin on the ECU. Either that or i messed up my wiring harness.
But an ethanol sensor would be spectacular. |
#18 |
Member#: 88322
Vehicle:2009 BMW 135i |
Ecuedit is a lot faster, 3D graphing is very good and fast, the logger is lightyears ahead of the game. Log tracing and log analysis tools in Ecuedit are very good. I've found it is a lot more effective when tuning because I don't have to drop the logs into Excel to have a good look at the data.
#19 | |
Member#: 103136
#20 | |
Member#: 99289
#21 | |
Member#: 88322
There isn't one or two items Ecuedit is ahead on. It is so far ahead on logging and analysis right now I could write several pages about it and why I use Ecuedit when tuning. For instance, I can slap up a load vs RPM graph with MAP in the cells and quickly tell what kind of effects changes in AVCS do, i.e. if I'm pushing more mass air for the same boost. I'm not knocking Enguinity. It's a great tool. I just think Ecuedit, if you're willing to pay for it, is well worth it. It is a superior program. It does more, in a more flexible way, and is WAY faster. It will be a long time before Enguinity catches up on the logging and analysis side of things even if the editor catches up. Being stuck in a Java platform will probably damn it to having CPU and memory utilization problems indefinitely. |
#22 | |
Member#: 63292
South East
#23 |
Member#: 44762
The next release of Enginuity will have huge improvements in speed and memory usage. You're right that Java will always be a bit of a hinderance, but poor design (and a bad decision in choosing which XML parser to use) while I was fumbling my way through learning XML is the one huge thing that's slowing it down right now.
I'll admit ecuedit has a lot of great features, and we're working on it. Simple logging is to the point where it is more or less complete, and after that I'd imagine Paul will start working on analysis tools. |
#24 | |
Member#: 88322
It sounds like you haven't even tried Ecuedit. If you don't pay for it, you get stuck with a delay timer when you do certain actions like save a ROM or start up the logger. I think someone else mentioned the wideband logger is also disabled. Everything else works normally. You should try it. You can open any log file (even ecuexplorer logs) and use its analysis tools. Or you can at least look at the editor. It's really great software. Blazing fast, feature rich, fairly intuitive, etc. It seems to me it is written from a more better direction. The + and - keys on the keyboard don't make changes that are WAY to large to be useful, so when I'm tuning on my laptop I don't have to manually key in values. It has had fast 3D graphing with irregular column/row gap compensation almost since first release. You can use your logs to trace and draw on top of the maps in the editor, which is just a phenomenal feature. The 2D and 3D log graphing tools are great and can be used for all sorts of cool stuff. It opens itself in <2 seconds, opens ROM files in <5, saves pretty much instantly, has a dashboard logger with alarms, etc. Too much stuff to list. If you want say it isn't a fair comparison, then this whole thread is pointless. Yes, it is free software vs. pay, but certainly it doesn't mean Ecuedit isn't $120 better than Enguinity. IMHO Enguinity still has a lot of catching up to do. The only draw for me right now is Enguinity takes less effort to get good XML support. For my own car I don't care, I have my own highly customized XML built off a XMLwrite XML from a long time ago, but sometimes on other cars it is quicker to use Enguinity to kill a DTC. |
#25 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
Sounds like we've got a lot of work to do to get Enginuity caught up w/Ecuedit, but I already knew that, just don't have the time right now to code.
Thanks for your honest feedback, Freon. |
| Thread Tools | |
| Display Modes | |
| Pros and cons of sti 2.5 vs. 2.0 | TurboRex | STi Forum Archive | 8 | 01-15-2003 08:31 AM |
| Turbo back vs. cat back exhaust pros and cons | xfactor834 | Factory 2.0L Turbo Powertrain | 14 | 08-07-2002 01:00 AM |
| Pros and Cons of Twin Turbo vs Turbo? | ImprezedRS | Normally Aspirated Powertrain | 6 | 03-19-2001 09:35 PM |
| WRX vs. A4 1.8TQ Chipped: pros and cons | superg | WRX Forum Archive | 31 | 02-24-2001 08:29 AM |
| Pros and Cons of 3" Exhaust Vs. 2.5" | stimpy | Normally Aspirated Powertrain | 14 | 01-30-2001 09:50 PM |
