Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 11-26-2001, 03:28 PM   #1
DrunkenMonkey
Member#: 3100
2011 WRX Hatch
Question Handling Problem on 00RS with P1 suspension setup...any help?
Okay i am learning more about suspension all the time..and my car has been having a problem lately that it didnt have when I first installed the P1 setup...its having quite bad "push" in the front end..when I go around a corner fast the front starts to slide and go straight..the tires have plenty of tread on them and they are yokohama AVS intermidiates on 17' OZ P1 rims....it seems like the car has been doing it ever since I rotated the tires..okay when i did that I noticed that there IS a slight camber problem in the front left wheel which made the tire wear alot on the inner edge...but it seems like that would make the problem happen only on one turning direction..and actually help turning in the other..but the sysmptom is the same on both right and left hand turns...I do have a 22mm rear sway bar..no rear strut bar..no front strut or sway bars..it seems like the rear of the car would want to kick out..instead of the front sliding....does anyone know what could cause it..or any way to make it handle better?...and I havent ruled out the possibilty that it could be my driving. sorry this is so long by the way haha..any thoughts? thanks!
DM
DrunkenMonkey is offline   Reply With Quote
Old 11-26-2001, 03:36 PM   #2
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Sounds like you need an alignment and some practice
Take a look at www.drivingtechniques.co.uk
Or try a book from Amazon called "Going Faster" from the Skip barber driving school.
skidplatez is offline   Reply With Quote
Old 11-26-2001, 03:45 PM   #3
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Did you check, and/or change, the air pressures? I am betting that the rears have less pressure, and when you moved them to the front, that caused the push. Last time I was at the track, I was pushing really bad. Went in, checked the pressures, and they were all about the same. Took 2 lbs out of the rears, and added 1 lb to the front. The next session the car lost the push and was pretty much neutral. Basically, you want to run about 3-4 lbs more pressure in the fronts, depending on conditions. On the street, I run 38 front, 35 rear. At the track, I up it to 40 front, 37 rear.
Oh, and I am also running the P1 suspension with Toyo Proxes T1-S tires with a 20mm rear sway, stock front, and front strut bar.
Old 11-26-2001, 04:10 PM   #4
DrunkenMonkey
Member#: 3100
2011 WRX Hatch
Hey wsup tim..cool deal i'll check out my tire pressures when I get home....skidplatz thanks for the site i'll check that out as well
DM
Help Me With My Suspension Setup, Please? nerdydorkus Brakes, Steering & Suspension 2 08-13-2007 06:18 PM
help with a suspension setup tartay Brakes, Steering & Suspension 0 05-30-2003 12:34 AM
problem with custom stage 4...any help? b00st3d Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-18-2002 09:35 AM
Any interest in a P1 suspension setup? Tangmere Rocky Mountains Impreza Club Forum -- RMIC 0 05-06-2002 11:24 PM
P1 suspension setup for sale Tangmere Rocky Mountains Impreza Club Forum -- RMIC 1 05-06-2001 06:55 PM
