Old 11-26-2001, 02:31 PM   #1
Bruiser
Member#: 3353
2001 2.5RS
Blue Ridge Pearl
Question drain plug?
OK, it's time to swap out the gear lube for some good synthetic stuff. My question is....don't laugh....what socket size is the trasmission drain plug?
Bruiser is offline   Reply With Quote
Old 11-26-2001, 02:40 PM   #2
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Not a funny question at all.
It is a 15or17mm square drive (that's really hard to find)
BUT a 1/2" socket driver with no socket will work.
skidplatez is offline   Reply With Quote
Old 11-26-2001, 02:48 PM   #3
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Get a fumoto valve!
Mike
MagicMT is offline   Reply With Quote
Old 11-26-2001, 02:51 PM   #4
Bruiser
Member#: 3353
2001 2.5RS
Blue Ridge Pearl
Hmmm. yeah that worked fine for the differential. I'm looking at a BIG hex nut on the bottom of the tranny. Is that not the drain plug? It's bigger than a 19mm. If that's not the drain plug then where is it?
Old 11-26-2001, 03:47 PM   #5
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
21 mm
SubyTechMaster is offline   Reply With Quote
Old 11-26-2001, 07:33 PM   #6
inpreza kid
Member#: 3334
its a big 21mm bolt. its right before where the two header pipes joins together. make sure to wrap "Y" part of the header with something so you don't get gear oil on the header. it smells like crap when burned.
inpreza kid is offline   Reply With Quote
Old 11-26-2001, 07:51 PM   #7
Silverscooby27
Member#: 9124
2014 335i xDrive
Kinda an aside, but has anybody tried the magnetic drain plugs that supposedly collect metal shavings and the like from the engine? What are your opinions?
Silverscooby27 is offline   Reply With Quote
Old 11-27-2001, 12:13 PM   #8
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Our cars already have magnetic drain plugs in the tranny and diff. The Oil filter should pick up anything that would normally be stuck on a magnetic drain plug(in the pan). I have also heard some cars(not sure about Suby) that have magnets in the oil pan.
Size for Tranny drain plug and diff plug? sfwrx Transmission (AT/MT) & Driveline 11 09-15-2007 11:38 PM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
Oil drain plug size... Suba-RAW Newbies & FAQs 4 09-30-2001 03:25 AM
Crush ring for oil drain plug SurfingWolf Newbies & FAQs 10 06-01-2001 09:04 PM
