Old 01-16-2007, 06:31 PM   #1
acidrain088
Member#: 130973
Default wastegat duty cycle
in terms of lowest spooling am i corect in saying that at low rpms the wdc should be low. when do you want the wdc or do i have this all mixed up. if someone could clarify this or post up a stock map and a tuned one i would realy apreciate it.
acidrain088 is offline   Reply With Quote
Old 01-16-2007, 08:19 PM   #2
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
If yuo want low boost= low wastegate duty.
gaby is offline   Reply With Quote
Old 01-16-2007, 11:09 PM   #3
acidrain088
Member#: 130973
is the wdc measured in the time the wastegate is closed unlike injectors
Old 01-16-2007, 11:18 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
No it refers to the % of boost pressure available at teh compressor outlet that is applied to the actuator to hold it closed. The stock BCS is a "bleed" type, meaning that as it needs to open the WG to control or reduce boost, the % of boost pressure applied to the WG is less than max possible. You will notice that the line coming from the compressor outlet is T'd into the WG actuator, then through the BCS and into the air inlet. Think of a seesaw; more boost of the WG from exhaust than from actuator causes it to open in increasing amounts.
To reach target boost faster, raise the WGDC in low RPMs.
Make sense?
blkscooby is offline   Reply With Quote
Old 01-17-2007, 04:23 PM   #5
acidrain088
Member#: 130973
perfect thank you
EBC using PIC 16F84, factory solenoid and duty cycle map with correction john banks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-07-2002 03:29 PM
Injector duty-cycle connection rwroth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-15-2001 12:51 PM
Max. injector duty cycles-the debate continues gossamer_monster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 08-08-2001 06:56 PM
Ways to monitor fuel injector duty cycles? davidm_sh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-02-2001 06:51 PM
Understanding AVC-R solenoid duty cycle... SilverSubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-15-2001 07:22 PM
