Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-16-2007, 08:36 PM   #1
Paul04WRX
Member#: 134306
Default What tha Tactrix
Just got the cable and been reading on other forums and still don't know what tha i'm doing. Downloaded all the proper software and linked up with my car ok. But now what. Yall sound like you have some experience with this thing, some help please. Siting in my car waiting.
Paul04WRX is offline   Reply With Quote
Old 01-16-2007, 09:27 PM   #2
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
What do you want to do with it? Are you just going to load a generic map, learn how to tune yourself, datalog? Don't sit in your car to long, I heard it's cold in TX today.
silver arrow is offline   Reply With Quote
Old 01-16-2007, 09:30 PM   #3
Paul04WRX
Member#: 134306
Yes I want to load a generic map for right now and learn as I go.
Not cold in my garage.
But it's around 33 ish outside
Old 01-17-2007, 12:12 AM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
There is no such thing as a "generic" map. They are all specific to a year and stage of mods.
If by generic you mean open source map, you should start by logging your car's performance and understanding the map that already exists on it before you flash ANY map to it. Too many people are flashing maps without really understanding what they are doing.
I'm not trying to speak gloom and doom here, just a little wisdom.
We are all here to help though
blkscooby is offline   Reply With Quote
Old 01-17-2007, 12:46 PM   #5
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
He means generic staged maps.
Tell us what mods you have and we can tell you what stg map you need.
Old 01-17-2007, 02:01 PM   #6
Paul04WRX
Member#: 134306
invidia down, 3in all the way back, perrin up pipe
Old 01-17-2007, 02:53 PM   #7
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
www.osecuroms.org
Get the XPT stage2 map and go from there. .
ALaDDiN is offline   Reply With Quote
Old 01-17-2007, 03:03 PM   #8
Paul04WRX
Member#: 134306
Alright done all that and can't figure out how to flash my car computer. Hooked up the cable to car and connected the two green plugs and the jumper. What next?
Old 01-17-2007, 04:26 PM   #9
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Use ECUFlash to flash to the ecu
btw, You should read this before you screw something up,
http://www.scoobypedia.co.uk/index.p...ReflashingECUs
and this.
http://www.scoobypedia.co.uk/index.p...dReflashingFAQ
Chris
criscross79 is offline   Reply With Quote
Old 01-17-2007, 05:10 PM   #10
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
definitely start with datalogging first. Save the map on the ECU now to a rom file on your computer and just look at it. Start to learn what everything does and how changes effect them before you start making changes.
KAX is offline   Reply With Quote
Old 01-18-2007, 12:18 AM   #11
bofh
Member#: 59287
2007 WRB WRX
2004 WRB WRX (RIP)
You know, if you post in the local forums, you might find someone local to you that has done some of this. But then Houston is such a small town...
bofh is offline   Reply With Quote
Old 01-18-2007, 12:38 AM   #12
Paul04WRX
Member#: 134306
There's bofh of us here.
Old 01-18-2007, 12:18 PM   #13
humara
Member#: 53289
04 wrx waggin'
wrb
did you install the right drivers for your tactrix cable?
humara is offline   Reply With Quote
Old 01-18-2007, 12:44 PM   #14
Paul04WRX
Member#: 134306
I gues.
Old 01-18-2007, 01:19 PM   #15
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
there are no drivers for the tactrix cable.
Old 01-18-2007, 01:38 PM   #16
blkscooby
Member#: 44422
2009 G8 GT
Make sure your laptop recognizes the cable. If not, you will not be able to do anything in ECUFlash. When you boot the program, if the "Read from ECU" icon is highlighted, then your are connected. Sometimes laptops don't like the cable being pullged in while they are booted. Plug it in first and then boot.
Old 01-18-2007, 01:58 PM   #17
Paul04WRX
Member#: 134306
got it fixed and there are drivers for the cable it comes up automatically and askes you if you want to search for drivers just hit ok,
Old 01-18-2007, 02:47 PM   #18
rkramer
Member#: 118209
2015 WRX Limitec
really?? you sure about that? (hint, there are OS drivers for EVERY piece of hardware connected to a computer, unless it is handled by the underlying bios in some cases. (older style keyboards for example) I've written drivers for a couple different pieces of custom equipment, writing drivers sucks!
anyway, there ARE drivers, and they are a little touchy in fact.
Old 01-18-2007, 09:47 PM   #19
nomex ninja
Member#: 108222
2002 WRX stage-x
Midnight Black Pearl
The drivers for the cable are in the ECUFlash software.
nomex ninja is offline   Reply With Quote
Old 01-19-2007, 11:15 AM   #20
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Hey I like writing drivers!
gabedude is offline   Reply With Quote
Old 01-19-2007, 11:22 AM   #21
SQ3.0dotJP
Member#: 136330
# OCCUPY
if you plug th usb in before you install ecuflassh sometimes the drivers will get screwy. so install ecuflash, then plug the cable in
SQ3.0dotJP is offline   Reply With Quote
Old 01-19-2007, 05:32 PM   #22
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
Sounds like you got the connection right. Can you log data from your car? Before you get all gung-ho, I recommend that you get familiar with the way your car works right now. Understand what you're looking at and how it works before you start flashing maps doing pulls. I have seen people posting logs that showed slight issues on cars that were just running OTS maps. The problem was that the owners of the cars did not understand enough to be able to spot problems in the logs. Here is what you should know before you start flashing and tuning your car:
1. How to open and view and modify maps
2. How to log the car with meaningful data. Logging ALL data is not the answer.
3. How does boost control system work? What are wastegate duty cycles? What are boost targets? Which maps control which parameter?
4. How does fueling work? What is AFR? What does lean and rich mean? How does fueling effect EGTs? Which map controls the fueling?
5. What is ignition timing? How does it effect the performance of the car? How is timing related to EGTs? Which map controls timing?
6. How is each map interpreted by the ECU? What do the x and y axis mean?
Read these questions and see if you know the answers. If you don't know what I am talking about, you need to do some reading. Do the research, log the car, see if you understand how things work and go from there. Feel free to ask specific questions and we'll be happy to help out. Your original question was not specific and as you can see, you got a bunch of vague answers because we're all trying to figure out what you're trying to do. Good luck
BTW, the list I posted is just the start but it will point you in the right direction. Once you know where you want to be and what to do, it'll get easier and you'll see the light.
Ziggyrama is offline   Reply With Quote
Old 01-19-2007, 05:46 PM   #23
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
I ordered a cable - I'm pretty excited to start watching what is going on in there.
It'll let me put my engineering brain to work on something besides brakes.
?? for Ziggy - is a wideband 02 sensor and or high quality EGT guage worth it? At some point the VF-39 is either to get ported or replaced so I want to be prepared for self tuning. At least that is the goal which I only have moderate doubts about.
KNS Brakes is offline   Reply With Quote
Old 01-20-2007, 11:34 AM   #24
Ziggyrama
Member#: 53665
2012 Tribeca Ltd.
I think they are worth it if you can get a good deal on them. An EGT gauge is a safety net which will tell you if you're heading for trouble. I like to have it to know how things are running. Some get away with tuning without one. I feel that $100 (prosport EGT) is not that much to pay for added safety.
WBO2 is extremely helpful to really nail the fueling, especially if you are getting ethanol in your gas, like I do. I do not have one currently but I am planning to obtain one shortly to verify my fueling is on the mark. You can find LC-1 from Innovate for under $200.
I always say that you need right tools for the job. I think you'll be much more effective with them
Old 01-20-2007, 09:10 PM   #25
blkscooby
Member#: 44422
2009 G8 GT
Zig, awesome post. Hopefully people will read and decide to take the time to understande before flashing any map.
What tha **** svr_wrx Texas Impreza Club Forum -- TXIC 85 02-08-2007 10:49 AM
whats tha deal? ThaTaint Texas Impreza Club Forum -- TXIC 18 11-07-2002 06:21 AM
WBCN? what tha... Fish New England Impreza Club Forum -- NESIC 24 09-25-2002 09:42 PM
Traffic Saturday? What tha dealio? CosmoTheCat North West Impreza Club Forum -- NWIC 20 11-29-2001 09:29 AM
