Old 01-16-2007, 09:07 PM   #1
Sushiplate
Member#: 121055
2005 Impreza WRX
OBP (with custom swirls!)
Default Might be a dumb question.
I checked the FAQ threads, but how much oil should an 05' WRX have? And when I fill the oil filter, should I count that oil as part of theamount of oil to put in?
Sushiplate is offline   Reply With Quote
Old 01-16-2007, 09:18 PM   #2
leecea
Member#: 37359
2003 WRX
Usually there is a slightly different amount quoted with or without a filter change. However, IMHO these are guidelines and the dipstick is the real decision maker. My strategy is to put 4 qts in while car's on ramps (I use them to make the oil change easier). Then I back it down and run the engine for a minute, then shut it off and go do something else. A while later I'll check the oil and top it up based on dispstick readings.
EDITED for clarity: you should buy 5 qts for an oil change, but you won't need to use all of the 5th qt.
leecea is offline   Reply With Quote
Old 01-16-2007, 09:31 PM   #3
Sushiplate
Member#: 121055
2005 Impreza WRX
So it's 4 quarts?
Old 01-16-2007, 09:40 PM   #4
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Edit
Technically:
4.8 qts including the filter to be on the upper level.
3.7 qts including the filter to be on the lower level.
I think 4.2 qts excluding the filter. But who isn't gonna change their filter?
So yes, 4 qts is a good starting point. Add more if necessary.
FD777 is offline   Reply With Quote
Old 01-16-2007, 10:16 PM   #5
Sushiplate
Member#: 121055
2005 Impreza WRX
thanks for clearing that one up. I went to the store and didn't know how much I should get. So I just got a six pack to be on the safe side.
Might be a dumb question but ImprezaWRX02 Factory 2.0L Turbo Powertrain 0 07-12-2004 02:45 AM
might be a dumb question, but... wrxmania Texas Impreza Club Forum -- TXIC 9 03-12-2004 12:06 PM
Might be a dumb question, but what's that fan noise? volkl23 Factory 2.5L Turbo Powertrain 1 02-18-2004 02:14 PM
This might be a dumb question, but . . . banman Tire & Wheel 7 11-23-2003 06:53 PM
This might be a dumb question but... akm3 Interior & Exterior Modification 5 08-28-2001 07:33 AM
Message Board Statistics All times are GMT -4. The time now is 04:34 PM.
