Old 01-16-2007, 10:19 PM   #1
LeroyBKR
Member#: 137491
Default Need help.. I was told I could find help here...
Hey guys I drive a 2003 WRX and I recently just spun a rod bearing. I did some research on here about the sti short block swap and I checked out Crawfordperformance.com because I heard I needed certain pistons to run the short block with my wrx heads... Do they sell a short block with pistons that are for wrx heads? Which one is it... I have about 2500-3000 to spend, can I do the swap with these funds? Thanks guys...
LeroyBKR is offline   Reply With Quote
Old 01-16-2007, 10:32 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
HEllo welcome to the forum. Right above your thread you will find a Search icon. Click on that icon. Then type in STI shortblock. You will find all the info about the swap and what items you do infact need and items you dont need.
JMK508 is offline   Reply With Quote
Old 01-16-2007, 10:34 PM   #3
Bolster
Member#: 22290
2002 WRB WRX Wagon
You can find a lot in the built motor discussion forum. Lots of people are running STI short-blocks with WRX heads. I believe the STI's headgasket will work with the WRX heads better than the wrx gasket because it will lower the compression ratio. You should be able to get a shortblock and gasket kit and have some money left over with your budget.
Bolster is offline   Reply With Quote
Old 01-16-2007, 10:56 PM   #4
LeroyBKR
Member#: 137491
Koo thanks guys.. Is the one im suppose to order the the reconditioned s2 short block? Its 1923.90 plus the core fee...
I was told that I need to go to texting rehab. Have you? Subi Chicky Off-Topic 79 09-16-2008 05:12 PM
avice req: A friend was told that his '99 A4 1.8T needs a new MOTOR crowbar Off-Topic 18 09-11-2006 08:17 PM
I was told you could help gdcpony Legacy Forum 20 04-26-2006 04:39 PM
i was told to ask this here phillyuw North West Impreza Club Forum -- NWIC 14 08-12-2004 02:38 PM
I was told I needed a fuel pump from a DSM guy Shaitiger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-09-2002 06:15 PM
