Old 01-16-2007, 11:01 PM   #1
fearlessfairless
Member#: 91381
2004 STi wingless
Default Check Engine light is always on
Hey everyone,
I have an '01 2.5RS and my check engine light is always on. When I take the car to get smog'd, it says there is a misfire on cylinder 4 but I have taken the car to 4 dealerships and they all tell me they can't find anything wrong with the car and that there is nothing that can be done. I was hoping someone on here might have some helpfull info because I need to get this light off so the car can get smog'd. Thanks alot.
fearlessfairless is offline   Reply With Quote
Old 01-17-2007, 09:36 AM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Don't you hate it when "experts" just give up?
Have you disconnected the negative terminal of the battery and let it sit that way overnight. The next morning reconnect the the terminal, and do the hands off feet off basic start and warm up procedure. Maybe the cel will go away.
If not, you can request testing, or replacing, the spark plugs and associated wires. I don't know much about the RS ignition though.
z&cobb is offline   Reply With Quote
Old 01-17-2007, 06:18 PM   #3
badtaste
Member#: 116636
2003 impreza
black
try a coil pack and wires ive had to actually replace 3 pcms cause of somthing similar
badtaste is offline   Reply With Quote
Old 01-18-2007, 05:59 PM   #4
rick-l
Member#: 33868
2003 wrx
srp
Does this car have a wasted spark ignition? (1 coil per 2 cylinders) If so I doubt the spark would be bad in just one cylinder and I'm sure one of the experts changed the plugs.
You aren't losing any coolant are you? Where I'm going here is head gasket leak causing intermittent misfire (by intermittent I mean more than once per 3 drive cycles)
Did they look at fuel trim and see if there was excess oxygen or excess hydrocarbons in the exhaust? Where I'm going here is a bad fuel injector.
I take it the car runs/idles fine? A subaru dealership should have known all these issues so you may.......
rick-l is offline   Reply With Quote
My 2002 WRX check engine light is on and is overheating. SUBY1305 Newbies & FAQs 17 01-15-2010 01:26 PM
My check engine light is on but car is running fine. Ripper_AWD Normally Aspirated Powertrain 27 09-24-2001 11:59 AM
Check Engine Light Is On!! Ya its Yellow Factory 2.0L Turbo Powertrain 3 09-06-2001 06:35 PM
Uh Oh my check engine light is on Tainted South West Impreza Club Forum -- SWIC 21 07-27-2001 12:18 PM
Need Help-Check Engine light is on AndyHidley Technical Forum Archive 3 05-19-2000 01:35 PM
Message Board Statistics All times are GMT -4. The time now is 12:04 AM.
