Old 01-17-2007, 08:46 AM   #1
ryzies
Member#: 118548
sti shopping
Default tick tick tick
my car ticks a bit...like at idle it will tick once every second...as i gas it the ticks get quicker and quicker...i would say that it is injector tick but i'm not sure...i've heard people that have ticks when the motor starts and then it goes away...mine doesn't go away...i made a couple clips, but the sound is horrible...
ryzies is offline   Reply With Quote
Old 01-17-2007, 01:43 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Sounds normal to me. Subarus tick like sewing machines. Re-torque your coil packs as that's probably the cause. If that doesn't fix it, it's normal. Search for and read the Subaru FAQ that I wrote for more advice.
Old 01-19-2007, 06:34 PM   #3
tspaniol
Member#: 40215
Hi, I had a sound like that too. Mine turned out to be the camshaft belt tensioner. Heavy gizmo with oil inside. Something happens to it (leak and/or loss of pressure?) that causes it to just barely contact the engine block - but it leaves a mark on both engine block and tensioner from hitting it - and goes "tick tick tick" with each impact. Could be worse when engine is cold and under throttle. It is under the camshaft cover, so you can't see it without removing the cover(s). Dealer replaced mine under warranty.
tspaniol is offline   Reply With Quote
Old 01-21-2007, 03:50 PM   #4
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
mine has done the same since 1000 miles. im at 32000 now and still no issues. been to the dealership 3 times for it, and they say its normal.
v8eaterWRX is offline   Reply With Quote
Mystery noise. *tick tick tick tick....* DriftIt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-17-2008 10:04 PM
Tick, tick, tick, tick... So... While we're waiting for these boomers to retire... snvin Off-Topic 18 10-24-2006 03:09 PM
Tick tick tick tick tick tick.... Janq Off-Topic 62 11-11-2005 12:09 PM
Tick tock, tick tock, cya Sox BAM Off-Topic 68 10-06-2004 12:34 PM
Tick tick tick tick oldpreza Normally Aspirated Powertrain 10 05-13-2001 01:15 AM
