Old 01-17-2007, 11:49 AM   #1
Fast Eddy
Member#: 54396
Default Gas mileage vs temperature
Between 100 F and around 30-40 F, gas mileage doesn't seem to be affected. But, temperatures around 10 and below drastically affect mileage. Can someone smarter than me please explain this?
Fast Eddy is offline   Reply With Quote
Old 01-17-2007, 11:53 AM   #2
mr. m
Member#: 44229
2000 2.5 RS
blue ridge pearl
Longer warm up times and gas reformulated for lower temperatures. Winter gas is formulated for easier starting and has lower energy content than warm weather formulations.
mr. m is offline   Reply With Quote
Old 01-17-2007, 12:04 PM   #3
mkaresh
Member#: 117534
The size of the difference should come out in my site's real-world fuel economy survey. It's more sophisticated than most such surveys, and includes a question about temperature/AC use. (Ideally these would be two separate questions, but I'm trying to make the survey as easy as possible.)
When I have enough responses, I'll be statistically analyzing the results to pull out values for all of the variables. For now, I'm just posting responses:
Real-world fuel economy survey results
mkaresh is offline   Reply With Quote
Old 01-17-2007, 12:09 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
That, and your car runs super rich when the engine is cold, and if it's really cold out, the warm up process takes a lot longer. If you take shortish trips to work/school/whatever, you'll notice a drastic drop because of that.
Wiscon_Mark is offline   Reply With Quote
Old 01-17-2007, 12:14 PM   #5
MulletSlayer
Member#: 7044
2015 Crosstek
Colder air means it's more dense, so your EM compensates by adding more fuel so you don't run lean.
MulletSlayer is offline   Reply With Quote
Old 01-17-2007, 12:20 PM   #6
RallyLegacy
Member#: 114353
97 Legacy,
05 BMW M3
yes, but if you use less of the gas pedal because of the more dense air in the cold, then shouldn't that have no effect on fuel economy, or is there still an effect somehow?
RallyLegacy is offline   Reply With Quote
Old 01-17-2007, 01:14 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
But think about it. I know I definitely have to use more throttle when it's cold out to get the same level of performance out of the car.
I was more referring to the engine being cold, but yes, this is true. I'm just saying that our ECU tends to generously overcompensate from the time the car starts up till it fully warms up.
Old 01-18-2007, 01:55 PM   #8
Fast Eddy
Member#: 54396
It doesn't take very long for my car to warm up fulling. I have a hard time believing poor gas mileage during warm up makes that drastic of a difference. That means I'd have to be getting about 1 mpg in the 2 miles it take to warm my car.
My mileage seems to be unaffected between the temperatures of about 40 F to 100 F. But, under say 10ish degrees F, it falls dramatically. Why? Is this my imagination or have others noticed the same thing?
Old 01-18-2007, 02:10 PM   #9
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Have you actually collected any data concerning this??
I track all my fuel usage and the results are interesting. My MPG drops in early winter and stays that way for a fillup or two. Then it appears to return to "normal". I wonder if the introduction to winter fuel causes a response in the ECU and within 100 miles the ECU "learns" the new fuel again??
conker69 is offline   Reply With Quote
Old 01-18-2007, 06:14 PM   #10
Fast Eddy
Member#: 54396
I haven't written down the numbers but I mentally calculate everytime I fill up and it's dramatic. If we have a cold snap that lasts for a week and it never gets above 10 degrees F, it's very noticeable.
Old 01-18-2007, 10:12 PM   #11
pieces
Member#: 42964
08 STI, 03OBS, 99L
I read an article once arguing that the dense cold air provided enough wind resistance to decrease fuel economy by something in the neighborhood of 10%. It was a pretty compelling argument. I tried searching but couldn't find it again- sorry.
I used to believe in the takes longer to warm up and is rich theory, but I noticed poorer winter fuel economy even on long trips driving straight through on a tank.
pieces is offline   Reply With Quote
Old 01-19-2007, 11:35 PM   #12
Feign
Member#: 68604
06 STi
I've got an excel workheet of the last few months for my mileage. When the cold has snapped here my mileage has gone down slightly. I just attribute it to not letting the car "properly" warm up before taking off. I try and let it idle for 30 seconds to a minute.
Sorry for the big pic...
PM me if you want it.
Feign is offline   Reply With Quote
Old 01-20-2007, 11:58 AM   #13
LorenzoS
Member#: 50995
2002 WRX Wagon
You guys don't know what you're talking about. In the winter your Trunk Monkey gets cold and will run the engine at night to keep warm. This uses some fuel and is reflected in your lower overall economy.
It's a small price to pay to keep the little guy comfortable.
LorenzoS is offline   Reply With Quote
Old 01-23-2007, 07:29 AM   #14
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I vote Trunk Monkey! You do have to keep the little guy warm.
Seriously though. New cars have HGO's or Heated Gas Oxygen sensors so that 2 minutes after start-up, the ECU switches to a closed loop operation to effectively curb emissions and as a result to reduce warm-up / idle fuel consumption.
But once you start driving and the engine is not fully warm, the fuel/air mixture is affected more. Once at operating temperature, the fuel/air mixture continues to be adjusted, but the "warm-up" factor would no longer be a part of the equation.
The fact that it is winter does mean more dense air going into the engine and thus the ECU has to adjust the fuel/air mixture so that a lean condition is avoided. The oxygen sensors also adjust this fuel/air mixture for driveability and/or emissions purposes as well.
Here in the Northeast it is mandated that the gasolines sold are blended. Previously the gasolines were blended with MTBE (made to be expensive) or oxygenated fuel, for example, but are now blended with ethanol.
The blending effectively aides in speeding up the "burn-off" factor of the emitted gasses so they don't hang around at ground level during the winter. This also affects overall per tank mileage.
I think that I have effectively restated what most have said.
Oh well.
Old 01-23-2007, 08:13 AM   #15
OldBBhip
Member#: 131719
2006 Impreza WRX TR
Obsidian Black Pearl
Winter gasoline is blended to lower the vapor pressure. That makes the gas mix with air more readily at lower temperatures, probably has an effoct on the air to fuel ratio. Something else that has changed over the years, is fuel lines freezing. Rarely see that any more. There use to be a big market for additives to act like a fuel anti-freeze, Heet for example. The lower fuel economy may be due more to the temperature difference between ambient starting temperature versus normal operating temperature. There is no operator intervention when starting, manual choke or something, any more so it is up to the ECU to compensate.
OldBBhip is offline   Reply With Quote
Gas mileage vs. oil weight fred.r Newbies & FAQs 23 09-17-2009 09:18 PM
theoretical gas mileage vs power efficiency question csacom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-08-2009 09:04 PM
K&N / resusable air filters vs. gas mileage yo vanilla Service & Maintenance 2 08-01-2009 04:32 AM
Gas Mileage vs Mods thread Touge86 General Community 13 03-14-2008 05:38 PM
Legacy L vs Outback Gas MIleage? mc2 Legacy Forum 6 01-28-2007 12:29 PM
