Old 01-17-2007, 10:41 PM   #1
Bolster
Member#: 22290
2002 WRB WRX Wagon
Default UTEC + Reflash ?
I have not yet logged anything using my tactrix cable. I've become really accustomed to logging with my UTEC, but have decided that I need to learn something new.
My current setup includes modded stock injectors, and I've been getting misfire codes, even after reflashing and increasing the count to 5. I'd like to see if I can't reflash the ECU to run the modded injectors and then run my UTEC on top to control other functions (water/alchy injection and incorporating my WB02 into logs).
The big question is how will my logs be affected by running the UTEC? Will I have reliable data to look at, or will I be dealing with all the trickery of the UTEC? It's my understanding that I should have some base logs to look at before I go and change stuff with a reflash.
Bolster is offline   Reply With Quote
Old 01-18-2007, 11:37 PM   #2
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
I been doing it for a couple of month with impresive results on map 0. Do the reflash on map 0 and then drive at least 20 highway miles before setting the maps 1-5. The ECU has to learn after the reflash and I notice it will change the AFRS after 20-30 highway miles because the injector scale is never perfect like UTEC. I use Jeff UTI prog. to log, is more reliable and acurate with the wideband, anything else the ecuexplorer and enginuity work fine.
gaby is offline   Reply With Quote
Old 01-19-2007, 10:22 PM   #3
Bolster
Member#: 22290
2002 WRB WRX Wagon
^^^Thanks! That's what I was looking for.
FS : HR: Helix CBE and Utec delta rmstires MAIC Private Classifieds 6 06-04-2010 08:42 PM
utec+reflash > reflash? WReXd UTEC 3 09-24-2008 07:56 PM
Can you run a "blank" UTEC map over an EcuTek reflash, in which the reflash controls? scooterforever Engine Management & Tuning 42 05-05-2005 12:27 AM
UTEC and ECU reflash question. davidm_sh Engine Management & Tuning 4 10-18-2002 07:21 PM
