Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-17-2007, 11:27 PM   #1
EROC263
Member#: 96887
Exclamation Unable to transfer from PC to AP1.0 !!!HELP!!!
I posted this on the COBB forum but I thought I might give it a shot here since the audience is bigger...
Hi, I am once again having problems with my AP to PC connection. It will connect just fine and I can recieve maps from it but I seem to be unable to send maps . It seems to be some sort of setting issue but it worked just fine before. I could send and recieve maps with no problem. I have not touched a thing in the settings I have checked them but I don't understand the driver settings(i.e. bits per second, data bits, parity, etc.). It's just frustrating to know that I can get the maps from the port but not send them. Also sometimes the % counter on the AP screen will count to like 23 then maybe 42 another time but it usually never leaves 0. The % value also counts extremely fast when recieveing maps but very slow when sending. BTW I am using a USB to seriel cablew/null adapter since my PC doesnt have any 9-pin ports. Someone help me please.
EROC263 is offline   Reply With Quote
Old 01-18-2007, 12:02 AM   #2
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
Question
Same connector? What brand? I have a keyspan. Sounds like a bad connection/cord to me.
Try a different USB or double check your port settings, maybe from not using it its at default?
There is also an update that I had to do to get mine to work with XP and no serial port, just USB's.
ADR 04STi is offline   Reply With Quote
Old 01-18-2007, 08:21 AM   #3
EROC263
Member#: 96887
Can you send me the link to where you got your update? Also I forgot to mention that the error I am getting when the maps don't send. It along the lines of, Timeout period expired blah blah blah. No error code bc the AP stays connected but my PC will only accept transfers from the AP and not send. I looked all over for how to change the "timeout" period but no luck yet.
Old 01-19-2007, 11:22 AM   #4
EROC263
Member#: 96887
BUMP for help
Best Way to Xfer Audio from PC to Mac? scoobydrew06 Off-Topic 9 03-04-2007 08:21 PM
file transfer from comp to another comp via NIC possible? BigWrecKs Off-Topic 21 12-24-2005 12:26 AM
What would cause boost to drop from 19 to 0 suddenly? mycotopian Engine Management & Tuning 19 09-04-2005 02:49 PM
Do points transfer from Florida to New York wix Off-Topic 4 07-27-2003 07:22 PM
Ticket: Points transfer from CT to NJ? Kamil Tri-State Area Forum 8 02-03-2003 03:07 PM
