Old 01-18-2007, 08:44 AM   #1
luvdatrex
Member#: 99273
02 WRX
Default How to check for worn wheel bearing?
I was just wondering if there was any way to check to see if my wheel bearing is bad? I've have some noises coming from the driver side rear wheel when I make sharp right turns at slightly higher speeds. I know I need new rotors but I'm not sure if its them making the noise or possible the bearing.
Thanks,
-Russ
luvdatrex is offline   Reply With Quote
Old 01-18-2007, 09:40 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Jack up the car, make sure the handbrake is released, put a hand on the top and bottom of the wheel and shake it back and forth. If it moves, you have some bearing wear and should replace it. It will likely not move very much at all. Any movement is grounds for replacement.
Tony
Old 01-18-2007, 08:04 PM   #3
Meat Supply
Member#: 137902
---- so good
it sucks....
sounds to me like a wheel bearing, i've put about 4 on old cavs, but symptoms are the same it sounds like. have fun
Meat Supply is offline   Reply With Quote
How to check a bad wheel bearing gummy Newbies & FAQs 6 09-15-2007 08:49 PM
how to check for an exhaust leak? paosti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-11-2006 08:59 AM
How to check for broken timing belt ? Legacy Normally Aspirated Powertrain 4 07-10-2006 10:20 PM
How to check for available vanity plates? gregaruWRX Off-Topic 5 09-09-2005 06:25 PM
N00b question, how to check for good ground? TaiChih Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-15-2002 04:55 PM
