Old 01-18-2007, 02:25 PM   #1
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
Post Amsoil or Royal Purple
which one is better
5w-30 or 10w-30 syn oil.
is [email protected] oil filter is one of best for subaru's
garboplateNY88 is offline   Reply With Quote
Old 01-18-2007, 02:44 PM   #2
bluesubie
Member#: 767
04 FXT
Amsoil. No contest. The last three used oil analysis that I've seen posted here showed RP 10W30 shearing to a 20 weight. In one case it was in about 1,200 miles. Conventional wisdom says that the 10W30 is thicker at operating temps., but this is not always the case. Where do you live? What does the owner's manual say for your temps?
People say paper filters best but when I have the oil analysed on my FXT (OEM air filter) and my wife's OB (K&N panel), the OB always shows less dirt getting past the air filter. Maybe it's because the OB is sealed better, or because I drive in dirter places. I don't know.
-Dennis
Old 01-18-2007, 03:03 PM   #3
WRXINTX
Member#: 96712
I SECOND THAT ON THE AMSOIL!!!! IT IS PROBABLY THE BEST OIL OUT THERE....
GET AN SAE RATED SL oil NO MATTER WHAT YOU DO AND WHATEVER BRAND YOU BUY!!!!
It will decrease wear on the tappets and cams and protect the engine at higher loads!!
RYNO
WRXINTX is offline   Reply With Quote
Old 01-18-2007, 03:08 PM   #4
WRXINTX
Member#: 96712
https://www.amsoil.com/storefront/xlm.aspx
also, if you are in NY.....
cold flow is important!!!
haha... like you didn't know
Old 01-18-2007, 03:42 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I too think AmsOil is the best but I use 0w30 in the winter and 5w30 in the summer.
wrxdrvr is offline   Reply With Quote
Old 01-18-2007, 04:19 PM   #6
o2man98
Member#: 90762
2005 92x
Satin Grey
Go with the AMSOIL Series 2000 0w-30 and the EaO12 oil filter and you will be set year round.
0w-30 = https://www.amsoil.com/storefront/tso.aspx?zo=1132530
5w-30 = https://www.amsoil.com/storefront/asl.aspx?zo=1132530
o2man98 is offline   Reply With Quote
Old 01-18-2007, 10:10 PM   #7
garboplateNY88
Member#: 134113
05 LEGACYGT
Post
I have burning oil in my legacy and my 05 STI. In my legacy I use valvoline 5w-30 with mobil 1 filter and I just lost 2 quarts that's why I am switching to royal purple syn. Should I use 5w-30 or 10w-30. what would burn less oil.
Old 01-18-2007, 10:20 PM   #8
bluesubie
Member#: 767
04 FXT
Switching to RP will have little effect on using oil. You need to change viscosity. If you're insistent on trying RP and want to stop usage, go with their 10W40.
RP 10W30 UOA http://forums.nasioc.com/forums/show...referrerid=767
And another http://forums.nasioc.com/forums/show...referrerid=767
Basically you do not want an 30 weight energy conserving oil.
-Dennis
Old 01-18-2007, 10:39 PM   #9
AllWheelsDriven
Member#: 1737
2005 BMW zhp
www.vispoint.com
i was burning oil at 5w30 using royal purple,M1 etc. i switched to redline 10w40 and havent burned any yet in 2300 miles.
AllWheelsDriven is offline   Reply With Quote
Old 01-18-2007, 10:47 PM   #10
garboplateNY88
Member#: 134113
05 LEGACYGT
Post
What is the best site and cheapest site for buying Amsoil syn oil and what grade should I use if I decide to buy this oil. Oil that doesn't burn easy.
Old 01-19-2007, 12:17 AM   #11
Button
Member#: 20620
2006 Outback 2.5 i
Willow Green Opal
Talking Fyi
garboplateNY88:
The best & cheapest way to buy Amsoil @ a discount is to become a preferred customer ($20 yr) & purchase via their website. Call Technical Support & they can answer your questions pertaining what oil is best for your vehicle 715-392-7101.
Regards,
~Button
Button is offline   Reply With Quote
Old 01-19-2007, 12:54 AM   #12
norexyet
Member#: 39149
11 elantra
yea i said elantra
royal purple 10-30
norexyet is offline   Reply With Quote
Old 01-19-2007, 01:26 AM   #13
06grayrex
Member#: 116132
2006 wrx tr Stage II
sgm Jorge tuned -RIP :(
I would use Amsoil, the viscosity depends on if you have any oil useage. I run Amsoils 0w30. I would not use a K&N air filter...Yeah they flow really well but do a crappy job filtering dirt. I would use a Amsoil Ea air filter or an OEM air filter. I just installed a SPT intake and when the filter needs replaced I will change it to an Amsoil Ea filter if Amsoils has one that fits.
06grayrex is offline   Reply With Quote
Old 01-19-2007, 09:01 AM   #14
Corkfish
Member#: 39503
I use Amsoil 10W-30 year round in my XT. Has never used a drop of oil. I read somewhere that Royal Purple has moly in it. Not something I want in my engine.
Corkfish is offline   Reply With Quote
Old 01-19-2007, 10:38 AM   #15
garboplateNY88
Member#: 134113
05 LEGACYGT
Post
I meant oil filter not air filter
Old 01-19-2007, 01:06 PM   #16
crisdawg
Member#: 120906
ive been using the amsoil 0w-30 for a couple years now, if u become a preferred customer for like 10 bucks every six months u can get a pretty good discount.
crisdawg is offline   Reply With Quote
Old 01-19-2007, 02:53 PM   #17
norexyet
Member#: 39149
11 elantra
yea i said elantra
it is on amsoil's website. I used mobil 1 on my wrx, but it would burn about half a quart every 3k, switced to amsoil, burned a bit less oil, then tried royal purple, oil consumption was barely noticeable and gas mileage went up. That is all i have used in the Sti. Not saying amsoil is bad, just think royal is better.
Old 01-19-2007, 02:53 PM   #18
bluesubie
Member#: 767
04 FXT
Moly is a good thing. Your pistons are coated with it. Actually, clicking on the RP UOA's above, RP doesn't have much. Redline has tons and Havoline conventional oil has a lot as well.
-Dennis
Old 01-19-2007, 02:55 PM   #19
bluesubie
Member#: 767
04 FXT
Check some used oil analyses and get back to me. RP 10W30 is their best 20 weight. Just check the UOA's I posted above.
Look for a viscosity that meets European ACEA A3 specs. Even if you look at a 30 weight, an oil that meets ACEA A3 specs are thicker and more stable than oils that don't.
-Dennis
Old 01-19-2007, 02:58 PM   #20
norexyet
Member#: 39149
11 elantra
yea i said elantra
-Dennis
yea we use royal in all of our built motors and customer cars without oil consumption or any other issues, must be no good.
Old 01-19-2007, 03:10 PM   #21
bluesubie
Member#: 767
04 FXT
I didn't say it wasn't any good and I'm not disputing that you do not have consumption issues. It's just not worth the hype, IMHO, and there is a lot of evidence to back this up.
Would I want to use oil in an STi or LGT that easily shears to a 20 weight? No. It's not my opinion that RP 30 weights shear easily, it's a fact. It's probably fine though since I'm positive there are thousands of people driving around with 20 weights in the 400 hp STi's.
-Dennis
Old 01-19-2007, 03:58 PM   #22
Corkfish
Member#: 39503
-Dennis
Then why would Cummins ban using any moly products in its engines because of excessive valave train wear?
Old 01-19-2007, 10:40 PM   #23
06grayrex
Member#: 116132
Sorry I'm Blind and deaf
Old 01-20-2007, 02:20 PM   #24
Kangpreza
Member#: 134717
after i read this, i searched more about it. came out, AMSOIL and Royal Purple is top of the line. however, its been proven that AMSOIL came out little better than RP.
btw: is it AMS-OIL or AMSOIL read together.
Kangpreza is offline   Reply With Quote
Old 01-20-2007, 03:18 PM   #25
dibblejr
Member#: 94070
05 LGT
subscribed
dibblejr is offline   Reply With Quote
07 sti redline or royal purple? wht07sti22 Service & Maintenance 5 03-07-2008 04:56 PM
Redline or Royal Purple Transmission Fluid? subiee sTi Newbies & FAQs 7 11-16-2007 07:10 AM
Redline or Royal Purple transmission fluid for 4EAT WRX??? Alan l. Service & Maintenance 3 03-17-2006 02:51 PM
Where to purchase (LOCALLY) redline, amsoil, or royal purple in central PA? Asinine Mid Atlantic Impreza Club -- MAIC 18 02-26-2004 10:55 AM
Amsoil, Royal Purple, or Mobile 1? Irishman STi Forum Archive 25 07-28-2003 03:02 PM
